Author Topic: May 2020  (Read 105784 times)
Re: May 2020
« Reply #375 on: May 28, 2020, 20:57:36 »
May 28
Euphorbia
D850 - 28mm f/1.8g
Tom Hook
  • Tom
Re: May 2020
« Reply #376 on: May 28, 2020, 23:41:35 »
May 28
Euphorbia
D850 - 28mm f/1.8g
You have captured a sense of a floating world that I like very much.
Zang
Re: May 2020
« Reply #377 on: May 29, 2020, 00:00:10 »
May 1
Three musketeers and d 'Artagnan
Z6 - 50mm f/1.8S
Are they in a aquarium :D
Zang
Re: May 2020
« Reply #378 on: May 29, 2020, 00:02:13 »
It was hot but dry today.
Beautiful flowers Akira. What's their name? I think we had similar ones (not exactly same) back in 80s.
Re: May 2020
« Reply #379 on: May 29, 2020, 00:27:56 »
John and Fons, you both got to create ethereal nature.
  Urban lines and colors
Re: May 2020
« Reply #380 on: May 29, 2020, 02:49:27 »
Thank you, Zang!  This is hollyhock (Alcea rosea).
Re: May 2020
« Reply #381 on: May 29, 2020, 13:13:08 »
Being in Duckweed Shooting Mode is a challenge, but of course there is little need of ever leaving my home and another pot of coffee brewing :)
I've been documenting a peculiar feature of Lemna japonica Japanese Duckweed the last day(s), and found I needed to make my focusing stack in a slanted angle. This in order to capture the sequence of papules (small pustules or papillae) along the median nerve on the dorsal side. They are very small and tend to blend in with the frond surface unless one lights them very carefully. Even then, the task was much tougher than I had expected and I'm still not completely satisfied with the outcome, so keep on trying more.
Here anyway is the current setup on my kitchen table, comprising the Z7, Laowa 25mm f/2.8 Ultra-Macro lens (CPU enhanced), Heim fibre optics, Stackshot rail, and all bolted onto one of my old faithful and rock sturdy Nikon Multiphot stands.Magnification is 5X and next step might be going up to 10X with the Mitutoyo 10X objective. However the last rig is physically longer thus inherently more unstable in an orientation off normal, plus the Mitutoyo is more prone to flaring when lighting is tricky.
A snapshot with the 85mm f/3.5 Voigtländer APO-Lanthar on the NEX-5N Monochrome.
More coffee awaits the intrepid photographer :(
Re: May 2020
« Reply #382 on: May 29, 2020, 15:59:23 »
plant id please...
Re: May 2020
« Reply #383 on: May 29, 2020, 16:16:57 »
May be a Clematis vitalba, Gewöhnliche Waldrebe.
Re: May 2020
« Reply #384 on: May 29, 2020, 16:18:53 »
Thank you Tom.
Re: May 2020
« Reply #385 on: May 29, 2020, 16:19:38 »
Re: May 2020
« Reply #386 on: May 29, 2020, 16:20:51 »
Thank you Paco
Re: May 2020
« Reply #387 on: May 29, 2020, 17:09:34 »
Re: May 2020
« Reply #388 on: May 29, 2020, 17:10:11 »
Thanks Paco.  That's a fine urban grid.
Re: May 2020
« Reply #389 on: May 29, 2020, 18:38:37 »
Z7  Micro Nikkor AF-S  60mm f/2.8
