Author Topic: [Theme] 5x/1.2 on Df  (Read 14264 times)
Re: [Theme] 5x/1.2 on Df
« Reply #45 on: January 02, 2020, 11:25:12 »
Great series above. Ah, those poppies...
« Reply #46 on: January 02, 2020, 18:16:16 »
Third two Nikkor CRT 55mm f1.2. Fourth two Canon LTM 50mm f1.2.
I like the Wood sorrel flower (5th pic) !
Great series. :)
« Reply #47 on: January 02, 2020, 21:49:59 »
Toby, wow, quite a selection (images and lenses  :) ).
Thanks for sharing
Tom
Toby -
Ethereal! Stunning.
+1. I´m a fan of your feet shoot
« Reply #48 on: January 03, 2020, 02:23:26 »
« Reply #49 on: January 03, 2020, 02:25:13 »
at the corner :o :o :o (noct)
« Reply #50 on: January 04, 2020, 07:44:24 »
Okay, I pulled out my X=5, Y=2 for the first time in a while on a full-frame body, i.e. fp not Df (excuse me for the violation to the rule :P )
Roughly at 1:1 1:1.28 magnification and at f2.8.
EDIT: the initial magnification data was wrong.  Sorry for the confusion.
Bill De Jager
« Reply #51 on: January 04, 2020, 20:30:46 »
Well done, Akira.
« Reply #52 on: January 04, 2020, 22:14:09 »
Bill De Jager
« Reply #53 on: January 17, 2020, 06:00:13 »
More Canon FD 50mm f/1.2 L on the Df, both at f/1.2:
_DSC4164-2 by Bill de Jager, on Flickr
_DSC4244 by Bill de Jager, on Flickr
« Reply #54 on: January 17, 2020, 08:03:18 »
Really nice rendering! Lovely smooth Bokeh
« Reply #55 on: January 17, 2020, 14:30:41 »
Toby -
Ethereal! Stunning.
+1 I love your work, Toby, sensible sensitive light paintings
Bill De Jager
« Reply #56 on: January 18, 2020, 23:16:40 »
Thanks, Eric.
The two berries in the second photo show interesting optical effects.  I tried to focus on the larger berry, but there was too little depth of field to put the sepal (brown triangular thing in front of the berry), the front of the berry, and the small projection on top of the berry (pistil) all in focus.  The photo I posted showed what I decided was the best compromise focal zone.  Even so, focus is a bit soft due to aberrations; remember that the lens is on extension.  I get a slight sense of almost a 'glow' about the berries, which may be due to spherical aberration.
« Reply #57 on: January 20, 2020, 14:01:33 »
Spring is early this year.
It may just be my samle, but even with this light from the side, I get a lot of glow @f1.2, it goes completely away @f2.0
« Reply #58 on: January 20, 2020, 15:43:05 »
A trick is to avoid glow with these fast lenses, at full opening, is to underexpose the image by for instance approximately one stop, then in PP raise the exposure by similar amount, except the very bright highlights, by the same amount approximately ;)
« Reply #59 on: January 20, 2020, 15:53:28 »
Thank you Erik, will try next time the sun shines ;)
