Author Topic: Noct 58/0.95 - technical  (Read 44609 times)
Re: Noct 58/0.95 - technical
« Reply #45 on: November 05, 2019, 12:58:17 »
So, there is no fixed infinity stop then?
Nikfuson
« Reply #46 on: November 05, 2019, 13:13:21 »
Mechanical infinity is beyond ∞ with optical somewhere between. This can be to acomodate for the very slight physical change in the structure with temperature changes.
« Reply #47 on: November 05, 2019, 13:19:54 »
It seems it was a very good idea that Nikon added the tripod mount for precise focusing with the very slim depth of focus and to retain image sharpness - BTW how is the stability of the tripod mount?
Nikfuson
« Reply #48 on: November 05, 2019, 13:28:11 »
The stability is sufficient as it balances the setup (lens/camera) very well.
Nikfuson
« Reply #49 on: November 05, 2019, 13:29:10 »
Hope this works for you; here's a video of the focus scale from infinity to minimum focus distance.
https://youtu.be/Hkb3VN3fiD0
Nikfuson
« Reply #50 on: November 05, 2019, 13:48:22 »
A few close-ups of the lens:
« Reply #51 on: November 05, 2019, 14:45:45 »
Any thoughts about the old Noct f/1.2, which is not well corrected for aberration. I wonder if I should sell mine? Any reason I should keep it? Of course, I have not tested the new one, which did NOT arrive Saturday as it was supposed to. Getting it today.
« Reply #52 on: November 05, 2019, 15:55:27 »
Looking very much forward to your findings on the new Z Noct!
The 'old' Noct-Nikkor is quite a lot of money to have sitting around given you excel in APO-lenses as your main focus,,, but the new Z Noct will not fit F-mount!
« Reply #53 on: November 05, 2019, 16:02:45 »
I am using my D850 and D810 less and less all the time. I have a great old NOCT 1.2 copy, but I probably should sell it. And I should remind myself that a lens like the 100mm Leica Elmarit R is a very fine lens that I converted, like this shot here with the adapter and Z7.
« Reply #54 on: November 05, 2019, 17:15:49 »
amazing, Michael how you manage to outperform yourself with every new shot. I am sure the 0.95/58Z will be in very good hands...
Nikfuson
« Reply #55 on: November 05, 2019, 20:28:08 »
OK, time to adjust my impression on the gull wings at fast openings, here at f/0.95.
And a better view of the blur circles at f/0.95 and f/1.2.
Nikfuson
« Reply #56 on: November 05, 2019, 20:28:54 »
Landscaping at 0.95.
« Reply #57 on: November 05, 2019, 20:32:30 »
Gorgeous blur circles looking like smarties :)
« Reply #58 on: November 05, 2019, 20:42:19 »
The first photo from the 0.95-NOCT. Wide Open. The lens was scheduled to arrive last Saturday, which is why I had these flowers…fresh. Since then, the flowers went south. So, that’s the explanation for the flowers demise, which flowers are now finishing up.
The lens is MASSIVE. And so far, the only thing I am not happy with is that the helicoid turns a little stiff. Is this true for other users? It moves the lens on the tripod a little more than I would like. The bokeh is exceptional.
This is a stacked image, using Zerene Stacker.
Nikfuson
« Reply #59 on: November 05, 2019, 20:48:58 »
Lovely picture Michael!
Yes, the helicoid is on the stiff side but tonight when I shot some stars I found it to be an advantage, not easy to knock focus off.
