Author Topic: Noct 58/0.95 - technical  (Read 44579 times)
Re: Noct 58/0.95 - technical
« Reply #15 on: November 02, 2019, 18:01:46 »
Thanks great to see! Looking forward for more ;)
Nikfuson
« Reply #16 on: November 02, 2019, 18:15:21 »
Jpegs straight from camera.
Both at f/0.95, 1/60s and ISO1600.
Nikfuson
« Reply #17 on: November 02, 2019, 18:24:53 »
Bokeh at f/1.0 and 2.2.
« Reply #18 on: November 02, 2019, 20:58:25 »
Best to keep the lens wider than f/2 or perhaps f/1.8 to get circular bokeh balls, then. I'm a little disappointed that aperture blades should cut into the highlights this early when stopping down the lens.
Of course, focused distance also has a bearing, thus what distance was the lens set to?
« Reply #19 on: November 02, 2019, 21:20:38 »
Quite surprising the 11 aperture blades are that visible, they are supposed to be rounded,,,
Nikfuson
« Reply #20 on: November 02, 2019, 23:07:14 »
This is at closest focus distance, i.e. 0.5m.
Nikfuson
« Reply #21 on: November 02, 2019, 23:08:58 »
Here's at f/1.4
« Reply #22 on: November 02, 2019, 23:20:16 »
OK, so how is the behaviour towards infinity focus for these highlight balls?
Must say this is NOT the appearance I had expected from a lens in this class and price bracket.
Nikfuson
« Reply #23 on: November 02, 2019, 23:29:19 »
Sorry, I have only a series of near towards far at f/0.95. But will give this a go the next time I get my hands on it.
« Reply #24 on: November 03, 2019, 00:19:19 »
Yes, please do. Personally I'm too tied down with writing up papers at present to spend time chasing after the Ultra-Noct just now.
MILLIREHM
  • Vienna, Austria
« Reply #25 on: November 03, 2019, 16:40:46 »
Nikon raised stellar expectations for this lens
It appears as if it might fail to fulfill this expectations in all aspects
Thanks Nikfusion for providing these samples
Wolfgang Rehm
Nikfuson
« Reply #26 on: November 03, 2019, 18:57:46 »
Second round of testing commences tomorrow, with more «photography» type shots 😊
« Reply #27 on: November 03, 2019, 20:36:38 »
Interesting, the lens has 11 aperture blades. This is a first for Nikon as far as I can remember. Other Nikkors have 7 or 9.
Even rounded aperture blades start to show a polygonal shape when stopped down far enough, but depending on the geometry of the blades some retain a rounded opening for longer than others. In the pictures at f/2.2 the lens is already closed down over 2 stops - nearly 2 1/2 stops. The Noct is over a stop faster than any other current Nikkor you should expect the polygonal shape to start appearing at correspondingly wider apertures. On the other hand, it has 11 aperture blades, so the shape should be more rounded than lenses with fewer blades, and you would expect the designers to take great care on this feature, especially with this sort of lens.
Feel free to send me you serial number for my Nikon database :)
Question: the lens appears to have two filter rings, one around the front element, and a larger one on the front rim of the focus ring - I'm guessing the larger has 95mm thread and is for the hood?
Nikfuson
« Reply #28 on: November 03, 2019, 20:51:49 »
Useful info Roland. As I get the lens tomorrow to continue my trials I'll send you the serial. I suspect the outer threads are for the hood but will of course check and post accordingly.
« Reply #29 on: November 03, 2019, 21:27:43 »
According to the preview of DPReview TV, your assumption of two threads seems to be correct (0:40~, 1:54~ and 2:30~):
https://www.youtube.com/watch?v=H-uoDcKxjAM
FWIW, the Nikkor-O a.k.a. CRT Nikkor has 11 aperture blades.  :)
