Author Topic: A little DIY project with the huge typhoon approacing  (Read 11877 times)
Re: A little DIY project with the huge typhoon approacing
« Reply #15 on: October 12, 2019, 02:02:20 »
one more thing is tape red fluorecent light tubes to the tripod legs, it helps prevent kicking accidentally and also finding it if you walk away more than a couple steps
« Reply #16 on: October 12, 2019, 03:57:12 »
red light is required during the astronomy nights, if someone uses white light they get a quick reminder to turn it off
led lamps use pulses vs dc current to save battery, but that will require a bit of circuitry perhaps not worth the effort given the elegant simplicity of your lamp
Thank you, Armando.  The pulse would be nice, but it could be a bit tricky to make the whole circuit small enough to go into this particular housing.
Also, thank you for the advice of using the fluorescent red tube on the tripod.  That would also work when I use the tripod along the street or on the sidewalk.  In that case, the phosphorescent tapes (not necessarily red) would work, too.
Bear Dale
« Reply #17 on: October 12, 2019, 05:29:28 »
Nice work Akira.
« Reply #18 on: October 12, 2019, 14:28:47 »
lit!
mxbianco
« Reply #19 on: October 12, 2019, 18:03:54 »
Thank you, Airy, Tristin, Massimo and Fons!
Thank you for the interesting additional info from your real experience and scientific knowledge.
Actually my initial idea was to mount the red light onto the hotshoe,  But I changed the concept after realizing that one would need to see the equipment other than the camera body.  Also, you would have to make it brighter if you want to light wider areas at a time.
BTW, fingers crossed for the big one coming... You have the right attitude towards catastrophes, increasing the heartbeat does not help!
Ciao from Massimo
« Reply #20 on: October 12, 2019, 19:59:56 »
stay safe, dear friend
« Reply #21 on: October 13, 2019, 00:06:47 »
Keep safe, Akira.
JJChan
  • JJ Chan
« Reply #22 on: October 13, 2019, 01:13:51 »
Yes please keep safe Akira
« Reply #23 on: October 13, 2019, 01:26:23 »
Nice work Akira.
Thank you, Bear.
And thank you, Massimo, Frank, Anthony and JJ for your concern.
My place was not at all damaged.  But this Hagibis typhoon brought insane amount of rain that caused severe floods all along its course.  Many people are suffering...
« Reply #24 on: October 15, 2019, 08:22:30 »
Just found that my Fuji X-T3 does have the night mode.   ::) ::) ::)
