Author Topic: Nikkor-UD repair!  (Read 3134 times)
mxbianco
Re: Nikkor-UD repair!
« Reply #1 on: September 23, 2019, 19:17:15 »
https://richardhaw.com/2019/09/22/repair-nikkor-ud-20mm-f-3-5-auto/
 :o :o :o
That is a huge amount of work, kudos for the exhaustive photographic documentation. I have added the link to my bookmarks, just in case I have to disassemble my own sample (fortunately no need to do anything). Well, my sample is not AI converted, and from Roland's database there is no mention of an AI-conversion kit in the 4th lens batch (my serial is 476xxx), to convert it i will have to machine the aperture ring... unless Roland suggests that kits 19 or 20 are fine with my sample (btw, hard to find anywhere!)
Ciao from Massimo
« Reply #2 on: September 24, 2019, 11:18:01 »
The 4th batch uses AI kit 20. To avoid repetition, I only list the AI kit against the earliest batch, following batches should used the same kit unless another one is specified, or the lens is AI :)
mxbianco
« Reply #3 on: September 24, 2019, 11:45:34 »
Thanks, Roland. Will remember this convention for future lookups in your super database!
Ciao from Massimo
« Reply #4 on: September 24, 2019, 14:25:30 »
Thanks Rick! There is so much materiel in that lens wow,,, compared to the tiny 20mm f/3.5 Ais  :o ::)
Kit # 19 is available:
https://kamerastore.com/products/search-Conversion%20kit%2019/
mxbianco
« Reply #5 on: September 24, 2019, 15:33:51 »
Thanks, Erik! Unfortunately as Roland says, I need AI kit #20...
But thanks to this thread I've pulled the UD-Nikkor out of a cabinet and started looking at it, and found out the following (tested on an old D300):
  • It's not necessary to machine out any metal, only the rabbit ears have to be turned 180°, or removed altogether (if you don't want to use it on a vintage Nikon F/F2)
  • Naturally, a small piece of metal will have to be screwed on or glued at the appropriate position for f/3.5 to act as an AI-coupling ridge
So AI conversion in this case is really easy!
Ciao from Massimo
