Author Topic: Photoninja  (Read 15346 times)
Photoninja
« on: September 15, 2019, 09:11:16 »
Thats what you get when you dont update photoninja,
btw there is a new update including the Z mounts.
Re: Photoninja
« Reply #1 on: September 15, 2019, 09:18:48 »
I just got a message from Jim Christian, the maker of Picture Code (=Photo Ninja)
"If you shoot in either 12-bit lossless compressed or 14-bit lossless compressed, PN can open the images.   For the other formats (lossy compressed or uncompressed), you can convert to DNG and PN can work with that. "
A complete new version is coming.
"I've been slow to address these in V1.3.X because I'm completely immersed in the V2.0 project.  I actually have all the formats for the Z6/Z7 working in the V2.0 code base but can't easily migrate it to the V1.X code base."
Re: Photoninja
« Reply #2 on: September 15, 2019, 09:28:08 »
What is the problem here?  Wrong color of the background?
Re: Photoninja
« Reply #3 on: September 15, 2019, 10:01:11 »
No problem, but no true colours when you need them.
Re: Photoninja
« Reply #4 on: September 15, 2019, 10:46:11 »
So what's your preferred tool for PP Fons, Akira, John?
Re: Photoninja
« Reply #5 on: September 15, 2019, 12:09:33 »
Since I switched to Fujifikm, I've been happy user of Capture One Express Fujifilm which was actually one of the main reasons for my switch.
Re: Photoninja
« Reply #6 on: September 15, 2019, 12:14:30 »
CC is the best, if you want full control of processing your image. It helps of course if you master the layer/adjustment/masking techniques.
Photo Ninja is also strong and fast, but needs some workaround, as it is not flexible in the exact sizes for downloading your image. For Image-processing only.
And If little time, I use Irfanview, thé best quick raw-reader and processor.  Quick and flexible. And for free.
Re: Photoninja
« Reply #7 on: September 15, 2019, 13:10:22 »
Thanks guys.
My PP needs are modest
- Crop
- Adjust levels
- Sharpen
I found CNX-2 worked well for me and found the Local Adjustments U-Point tools really useful.
But one drawback of moving to a D500 was losing access to CNX-2.
I find NX-D clunky to work with, so am looking at alternatives.
I had the CC subscription for a year but found PS overkill and hated LR
Re: Photoninja
« Reply #8 on: September 15, 2019, 13:25:36 »
Thanks guys.
- Crop
- Adjust levels
- Sharpen
Colin, your situation coincides almost perfectly with mine.  I had never been in need of layers even while I was using CC.  I had just found that Photoshop Elements lacked some parameters of the RAW converter.
The last software I used with D750 was CNX-D and I didn't necessarily find all that different from CNX-2, although I do find that using C1 is far more intuitive.  And C1 Express Fujifilm is free!  Also Sony shooters can use C1 Express Sony.
The X-trans sensor has sometimes been criticized for its "wormy artifact", but I haven't encountered any.  I haven't used any software other than C1.
Re: Photoninja
« Reply #9 on: September 15, 2019, 13:46:26 »
It all depends on your needs, indeed.
To clarify, basically I use Irfanview, were most people use lightroom (as a kind of catalogue too) and send the files to the different processors.
In CC I use then mainly Camera-Raw and some fine-tunings later in CC.
Re: Photoninja
« Reply #10 on: September 15, 2019, 13:51:48 »
The only "special" thing I do is pano stitching.  I used Photomerge in CC and I thought I would miss CC for that.  But it turned out that Image Composite Editor (free stitching software from Microsoft) worked great.
Re: Photoninja
« Reply #11 on: September 15, 2019, 14:51:40 »
But does ICE  read NEF's?
Re: Photoninja
« Reply #12 on: September 15, 2019, 18:26:45 »
I mainly use photoshop the ability to use more layers for instance.
Re: Photoninja
« Reply #13 on: September 15, 2019, 18:32:39 »
Capture One is an excellent processor.  It has layers and luminosity masking.  It produces outstanding results from X-Trans files, unlike Adobe.
I have been revisiting some of my Nikon images, and obtaining noticeably improved results in C1.
But for ultimate image editing, Photoshop remains king.
Re: Photoninja
« Reply #14 on: September 15, 2019, 19:22:25 »
