"NG 10 Years" competition: RESULTS !!!https://nikongear.net/revival/index.php?topic=11252.0Current status: 86/150 supporters
Did a test on a focus test target.The focus is spot on, so Eriks explanation about the intelligence of the Z cameras are right On this flat surface the problem is eliminated.The image is taken at minimum focus distance.
In Photoshop, ACR you select to use the profile or not,,, no big deal! I love the vignetting it has wide open!
how about lightroom i only use photoshop for adding mosaic to my hands
Switch-off all the related settings in camera, and you should be fine in Lightroom...
Pretty certain that there's no option in either of the Adobe programs to opt out of using the in-built lens corrections with the Z series - the only option is to use other raw converters
No, but switching off the relevant parameters IN CAMERA (and changing the embedded lens profile) does mean that Lightroom does not apply the corrections.
Great for portraitsZ7
I can see that - what a gorgeous cat! Hard to get them to sit still for long.
