Author Topic: Nikkor Z 50mm f1.8 S  (Read 28589 times)
Re: Nikkor Z 50mm f1.8 S
« Reply #120 on: November 06, 2020, 14:22:06 »
Did a test on a focus test target.
The focus is spot on, so Eriks explanation about the intelligence of the Z cameras are right ;)
On this flat surface the problem is eliminated.
The image is taken at minimum focus distance.
Thank you for confirming your camera and lens are able to focus correctly without any issues re focus shift. very good!
fish_shooter
    • Salmonography.com
« Reply #121 on: November 06, 2020, 19:37:25 »
I suspect the focusing speed has more to do with evaluating the image data much as we would do with our brains in MF mode. Hence the need for an additional CPU in the series II Zs. Speed as well as accuracy is probably enhanced if the "AI" in the CPU programing is set to seek out defined targets like faces and eyes.
« Reply #122 on: November 06, 2020, 19:47:54 »
Yes the Z7II and Z6II should have more accurate focus in 'pressed situations' like when doing face/eye tracking.
Also, it's maybe good to turn off eye/face recognition when doing flowers  ;)
The Z7 is already fine for the type of video work I do with the Z 50mm f/1.8 S - It's much better, faster more reliable than any F-mount AFS lens I have, for instance the AFS f/2.8 trinity lenses and at the same time adjusting focus completely silent.
« Reply #123 on: November 30, 2020, 14:15:22 »
Great for portraits
Z7
« Reply #124 on: November 30, 2020, 14:29:24 »
i almost bought this lens on a whim...
until i realized that Z cameras add lens profile to your photos!!! :o :o :o
this ia pointless since i dont want any lightroom correction and i couldnt turn it off! ::)
Damn you panasonic... (or was it olympus who forced them to do that)
« Reply #125 on: November 30, 2020, 14:42:04 »
In Photoshop, ACR you select to use the profile or not,,, no big deal!
I love the vignetting it has wide open!
« Reply #126 on: November 30, 2020, 15:10:46 »
how about lightroom :o :o :o
i only use photoshop for adding mosaic to my hands ::)
Eddie Draaisma
« Reply #127 on: November 30, 2020, 15:13:56 »
Switch-off all the related settings in camera, and you should be fine in Lightroom...
John Harkus
« Reply #128 on: November 30, 2020, 19:56:23 »
Pretty certain that there's no option in either of the Adobe programs to opt out of using the in-built lens corrections with the Z series - the only option is to use other raw converters
Eddie Draaisma
« Reply #129 on: November 30, 2020, 20:00:20 »
No, but switching off the relevant parameters IN CAMERA (and changing the embedded lens profile) does mean that Lightroom does not apply the corrections.
« Reply #130 on: November 30, 2020, 22:05:05 »
Or use an older version of the program without the lenses profiles yet?
« Reply #131 on: December 01, 2020, 02:07:14 »
i couldnt find it :o :o :o  which icon is that under?
« Reply #132 on: December 01, 2020, 04:07:00 »
I can see that - what a gorgeous cat!  Hard to get them to sit still for long.
Great for portraits
Z7
« Reply #133 on: December 01, 2020, 07:49:50 »
Thanks Hugh.  It's not easy, but you need to find her moments of 'relaxation'   ;)
« Reply #134 on: December 01, 2020, 09:50:57 »
Some lens corrections done in-camera by the firmware can't be changed on Photoshop.
Photoshop 'Lens corrections' can be turned off as you choose;
https://helpx.adobe.com/camera-raw/using/correct-lens-distortions-camera-raw.html
