Author Topic: The new Noct 58mm f/0.95 - Bet and Win!!!  (Read 53008 times)
Re: The new Noct 58mm f/0.95 - Bet and Win!!!
« Reply #60 on: October 28, 2019, 19:53:44 »
Run straight through with no corrections applied -- probably could be tweaked better but that wasn't the point here.
The main impression is the lens is insanely sharp, but in a very smooth, velvety manner.
« Reply #61 on: October 28, 2019, 19:59:43 »
Yes agree, what do you think about the glare, skin is it all down to the light
« Reply #62 on: October 28, 2019, 20:07:12 »
Yes, think so. With a lens of this calibre even the minor flaws are mercilessly revealed.
« Reply #63 on: October 28, 2019, 20:45:32 »
A small under-exposure would change the effect of the glare a lot, often seen it shooting the classic Noct-Nikkor as well as other sharp fast lenses wide open like 50mm f/1.2 f/1.4 and lately I have seen it on 105mm AF-D f/2 DC - small changes in exposure can have huge impact on reducing glare and issues with highlights.Rendering is close to Noct-Nikkor, smooth tonal transitions - Very nice!
MILLIREHM
  • Vienna, Austria
« Reply #64 on: October 28, 2019, 20:50:58 »
Some portrait pictures, I'm not impressed to be honest, I had much higher hopes for a cleaner image regarding APO correction. They also show how difficult it is to get the focus right. Most funny detail is that f/0.95 turns into f/1  ::) That is just not ok...
https://www.dpreview.com/sample-galleries
Not too impressed too  by the galleries available so far.
BTW there appears not be too much practical difference between f/ 0,95 and f/1 - more like a renommée issue (like the former 1/300 X sync speed). Nikon should have been more courageous and make this lens f/0,5 or at least f/0,7
Wolfgang Rehm
« Reply #65 on: October 28, 2019, 20:56:28 »
f/0.7 would incur minimum 4*weight of current design.
MILLIREHM
  • Vienna, Austria
« Reply #66 on: October 28, 2019, 21:05:10 »
Probably yes, but that would not be the heaviest lens that had been lugged around (the 7 kilo 300/2 or my 6.x kilo first version of the 600/4 comes to mind). yes its insane for a "standard" focal length but even the f/0,95 Noct is the first 58 mm with tripod mount
Wolfgang Rehm
« Reply #67 on: October 28, 2019, 21:10:46 »
That would be a monster  :o I think they are on the money with sharpness and the look and feel, the corrections are just a (the only) compromise they apparently had to do,,,
mxbianco
« Reply #68 on: October 29, 2019, 08:38:35 »
Well, a huge variation in prices all round the world...
(today's exchange rate)
Japan 1265000 JPY = 10469 €
Norway 93990 NOK = 9205 €
Netherlands 8999 € = 8999 €
USA 8000 $ = 7213 €
That's a fork of about 2800 € !!!
Now, the results of your estimates.
If a bracket  (Francis: 4000$ to 7000$) has been given, I have averaged it out to (low+high)/2 (=5500$ = 4959€)
All converted to €
1st Frank Fremerey: 5729 € (wins trip to Mars)
2nd Birna Rørslett: 5590 €
3rd Bill De Jager: 5407€
an then Erik, Francis, Nikfuson, Pluton, Aguinaldo (4959€ down to 4057€)
Fons, I don't have a converter for old currencies, I have to pull your estimate of f 2.93 :(
Ciao from Massimo
« Reply #69 on: October 29, 2019, 17:30:11 »
Yes, the shots I've seen besides Birna's have not impressed me. Perhaps many of the photographers are not used to manual focus?
arthurking83
« Reply #70 on: October 30, 2019, 16:15:50 »
Even after all this time, I'm still not 100% convinced that CNX-D was the ideal path for Nikon to take. CNX3 would have made more sense .. anyhow
There seems to be a very small distortion associated with the lens too.
EXIF/makernotes don't seem to display it, but distortion control was activated on the file in CNX-D. Made a very very small difference to geometry of the image switching on and off .. and the reason for my distrust of CNX-D
Whilst clicking distortion control on and off, I also noted a huge colour change in the image. Like it went from Portrait to Vivid(or Landscape) and or a WB change.
Models skin changed to a warmer rendering  .. nothing else played with other than the tick box for distortion. Very strange.
Anyhow, Erics comment re slight green on right eye .. easy fix in CNX-D with the activation of the axial color aberration(from off to on) .. default setting is 50(not touched) .. just clicked on. fixed.
(image converted in CNX-D).
Only edit was to the axial color aberration in CNX-D. Distortion was left at on(as shot).
Like Birna said .. insanely sharp considering wide open and such a wide aperture. For some reason, the online jpg doesn't render anywhere near as sharp as on the PC too.
By default, portrait only uses a low sharpening routine, and fairly coarse at that. Setting sharpening to (say) 4 instead, renders even more pop in the sharp areas of detail. tweaking even more reveals even more again. Very good .. in face insane!  ;D
Arthur
« Reply #71 on: October 31, 2019, 19:17:55 »
Now in stock in Copenhagen  8)
« Reply #73 on: November 01, 2019, 03:10:16 »
My copy of the NOCT was charged to my card today at B&H, so I assume they are readying it for shipping. It will arrive tomorrow, Saturday, Nov 1st. I can't wait. For me, for the work I do, this MAY be the perfect lens. If not, back it goes. LOL.
Nikfuson
« Reply #74 on: November 01, 2019, 15:56:26 »
I will (if Murphy doesn't intervene) get my hands on the Noct tomorrow...no, not buying  :)
Will report back in due time with findings.
