Author Topic: ISCO-GOTTINGEN ISCONAR 100mm f/4  (Read 10135 times)
Ian R
Re: ISCO-GOTTINGEN ISCONAR 100mm f/4
« Reply #15 on: February 25, 2019, 13:56:38 »
The F mount is 1mm longer in register plus the adaptor so any lens able to reach infinity on the F mount with adaptor would well overshoot on an M42 camera. I used a micrometer to set my adapter, and with a 50mm f/2.8 M42 Zeiss Jena, that overshoots infinity just a little. I don't think lens calibration was that exact back then. I calibrated my 100mm shown here by using the moon. Now just before the lens hits the focus stop I can feel the helical just starting to bottom out.
I used to spend hours with a ground glass and a loupe calibrating my old rangefinder cameras. Bit of a waste of time really, but at least I learnt something - and got the cameras working their best.
« Reply #16 on: February 25, 2019, 22:51:16 »
Lovely images and nice rendering. Shows you don't need a super-fast lens to get nicely defocused backgrounds.
« Reply #17 on: February 26, 2019, 09:09:44 »
There are a number of M42 lenses which can reach infinite focus with a very slim F-M42 adapter, especially if the focal length is longer than 85mm.
We can say that. in my experience, I get infinity provided with F bodies if you stop down toward f/22 thanks a deeper DOF. At full aperture I don't. (using the 100mm f/2.8 trioplan)
This is why I am expecting a true infinity with a M42/Z adapter ring I ordered recently for my Z6 I bought few days ago.
Wait and see, but I am glad Ian confirmed it... :)
Ian R
« Reply #18 on: February 26, 2019, 20:55:17 »
Did you order the Pixco adapter? That reached infinity perfectly, however a couple of points. The Pixco is exactly 0.1mm too short. This is by design, but its good that it is an exact figure as by adding a 0.1mm shim under the metal threaded insert you are now spot on to M42 standard. Coper tape is conveniently 0.1mm. Also the internals are not treated with any anti-reflective material. I added my own high quality flocking.
Now I feel happy that I have got it right as can be and I can hunt down some more M42's.
« Reply #19 on: February 26, 2019, 21:58:40 »
I've ordered this one : https://www.ebay.co.uk/itm/M42-screw-mount-lens-to-Nikon-Z-mount-full-frame-mirrorless-camera-adapter-Z6-Z7/401646385553
This is Roxsen stuff which I know already the quality. But it is written ''Pixco'' on the item. It seems black inside but no mention on the description. Will see when I get it.
I love the aluminium body lenses : I am seeking a primagon 35mm (meyer optics) in M42 mount. Unfortunately, there are mostly in Exacta mount. ::)
Ian R
« Reply #20 on: February 26, 2019, 22:30:47 »
That's the one Rosco. Very nice machining - I appreciated that - but do add some internal light damping if you can. I had some black 1mm light trap felt which was just enough to do the inside. If you don't, you may run into instances where the light bounces about inside.
FGAng
  • Mixing the old and the new Nikkors
« Reply #21 on: February 28, 2019, 01:53:30 »
I am guessing the rear element of this lens is recessed in and thus won't hit the mirror of a FX Nikon when adjusted to infinity, is that correct?
Can you describe how with a screw driver infinity is adjusted?
Thanks.
Ian R
« Reply #22 on: February 28, 2019, 11:46:59 »
Thanks.
Absolutely no mirror interference - there is only the lens mount at the rear.
To set infinity you remove the front lens ring with a rubber lens wrench, then loosen the three screws underneath - this allows the focus collar to move independently from the optics. You can then set up the focus to match your adapter and re tighten the screws.
FGAng
« Reply #23 on: February 28, 2019, 13:12:54 »
Thank you that is very helpful.  So long as the movement range is not too big this is a simple way to achieve infinity focus.
« Reply #24 on: March 12, 2019, 08:38:24 »
Have a look here: https://www.photohaus.de/shop/meyer-optik-primagon-45-35mm-m42/
« Reply #25 on: March 12, 2019, 14:20:27 »
Thanks for the link, Bent !
I had a look (with the help of Google translate ! :))
Price is correct but the postage is too expansive (29€)
I just got an adapter (Exacta to Z) in case... ;)
« Reply #26 on: March 12, 2019, 16:06:46 »
You are welcome Francis.
The postage is too high for items that cost 69€ :o
« Reply #27 on: March 13, 2019, 11:42:32 »
And regarding the size/weight (155gr.) ! :P :D
