Author Topic: A special f4/350mm UV-VIS APO CAT lens from the russian Mission to Mars  (Read 5800 times)
JCDowdy
Re: A special f4/350mm UV-VIS APO CAT lens from the russian Mission to Mars
« Reply #15 on: February 13, 2018, 16:06:55 »
Sharp and red like that roadster now coasting to Ceres!
If that DEO-TECH OWL doesn't suit you might consider the Starizona Filter Slider.
    https://starizona.com/acb/Starizona-Filter-Slider---Complete-System-P3518C91.aspx
I have one and it is quite robustly built.
If the diameter is similar you could drill and tap holes for your lens mounting flange.
John C. Dowdy, Ph.D.
« Reply #16 on: February 13, 2018, 17:42:44 »
Thanks John, I have already several alternative filter silders here!
Macro_Cosmos
    • Flickr
« Reply #17 on: February 14, 2018, 14:33:35 »
Aww yeah, I can feel your joy :)
Looks absolutely amazing, the results are looking great too. Just wondering, how much did you pay for it? I have a hard time finding weird exotic stuff online.  ::)
Blog: Diatoms Australia
« Reply #18 on: November 17, 2018, 18:07:23 »
Well, I'm quite excited to report that I just found and bought the grandfather of this ZUFAR-2 space lens from the Russian planet Mars exploration, thanks to my russian friend(s). It is a prototype lens with a very different internal name Ob-512, but company data (LOMO) confirmed my suspicion, it is indeed one or even "the" factory prototype of it.
Zufar-2 CA on bottom, Ob-512 protoytpe on top
Bit larger, quite heavier the prototype was - they changed the materials for the final product and saved aprox 20% weight (2.2 kilograms down to 1.8 ), very important for a 1976 space lens. The technical data of the final lens got also improved, viewing angle from approx. 3 degrees to 5 degrees, UV-VIS transmission from >50% to >57% (200-700nm). Back focal length remained at 51mm, very useful for a later adaptation...
« Reply #19 on: November 17, 2018, 18:45:40 »
Apparently a very useful friend .... looking forward to actual images.
« Reply #20 on: November 17, 2018, 21:28:35 »
Wahnsinn, Klaus. 10 Jahre warten und dann. Gratuliere!!!
« Reply #21 on: November 17, 2018, 22:55:49 »
Yep, that's what I expect it to be! I will certainly take some images, but in December when it finally will have made it here, there won't be much left to show...
Das war für das ZUFAR-2, dieses hier hat mich gefunden... ;-) Dankeschön!!
« Reply #22 on: November 17, 2018, 23:02:58 »
Amazing story.  Congrats, Klaus!
« Reply #23 on: November 17, 2018, 23:23:07 »
Arigato domo Akira!
