Thank you JA, Akira, and Simone! I am thoroughly enjoying every moment.
Today I shot with D750 and 20/1.8. The idea behind it is to compare images that I took yesterday and determine once and for all why would I take IR images in the first place. OK, the field of view isn't exactly the same between the 10.5 mm in DX and 20 mm on FX but it is not that far apart.
With that in mind I took a shot of the big bell from the more or less exact location, and then I tried to process the image to match as much as possible the IR image I took just a day earlier. The 20/1.8 is a lens I highly recommend! I cannot determine which is better, probably the IR image because of the more interesting foreground
![Smiley :)](https://nikongear.net/revival/Smileys/default/smiley.gif)
1. The big bell;
2. Answering messages and reading the news for breakfast;
3. The colors of the Adriatic Sea;
4. Boats (Paco);
5. The containers and pine trees;
6. 20/1.8 can also do portraits although I admit I should have opened the aperture more instead of the f/8 that I used, oh and it is the only shot that I cropped thus far.
Thank you all again for your comments and encouragements.
What will I use tomorrow?
