Author Topic: The color white  (Read 6102 times)
The color white
« on: June 11, 2017, 06:59:50 »
Re: The color white
« Reply #1 on: June 11, 2017, 08:15:35 »
I am confused. Please explain
Andrew
Re: The color white
« Reply #2 on: June 11, 2017, 09:47:32 »
Solarization??
Andrew Iwanowski
Re: The color white
« Reply #3 on: June 11, 2017, 14:47:07 »
The area under construction is to be all in white with a skylight at the top which is larger than my house (200sq meters). However now it is covered and filled with darkness and dank construction equipment. This was my reaction to that by mucking with the levels curve.
For a long time I have not had an attraction to the false colors of IR photography or the bold posterization that is often seen in Bjorn's work, but now I am seeing it as a reaction to the absence of light that must be present in those dimly lit places at the top of the world. If there is no color, we make it.
Re: The color white
« Reply #4 on: June 11, 2017, 16:59:47 »
Hm. I did guess something like it. Better to hear from the creator. The panels at the lower level: are these glass or concrete?
Concerning low light levels I have seen a transformation of thought since I used the D5 with 100k ISO fairly usable: I take the shot and look at the display immediately afterwards to see "vision outperformed" leterally.
Re: The color white
« Reply #5 on: June 11, 2017, 18:04:57 »
Frank,
The atrium is mostly steel, glass and gypsum board with grey terrazzo floor.
Right now it has every sort of building material exposed along with scaffolding and wooden planking. Looks a bit like a mine or dungeon, but should be clean and bright in a few weeks.
Re: The color white
« Reply #6 on: June 11, 2017, 20:49:42 »
Frank,
I wish I could have started my house already, but legal issues and design optimization delayed it. As long as it is finished Christmas 2018, it is OK
Re: The color white
« Reply #7 on: June 11, 2017, 21:13:12 »
Good luck with it. Show photos as it moves along!
Re: The color white
« Reply #8 on: June 12, 2017, 08:23:02 »
I can PN you the drawings, you seem to be able to read them properly....
Re: The color white
« Reply #9 on: June 12, 2017, 14:33:32 »
I am an architect.
Re: The color white
« Reply #10 on: June 12, 2017, 21:37:01 »
I am an architect.
That is what I concluded. Drop me a PN with your Email and I can show you the state of the project. Depending only on the building authority now, it has become a beauty in my eyes of a lay man. I start to move in the house and breathe
CS
Re: The color white
« Reply #11 on: June 12, 2017, 21:41:58 »
I'd like to see it too!
Carl
the solitaire
Re: The color white
« Reply #12 on: June 13, 2017, 00:12:26 »
Jeck, I like the way you express your emotion towards what is (or is not) happening at that site.
I did a series of photos, many years back, trying to express my emotional response to my surroundings at the time. That was on large format Kodak T-Max film. Nowadays, with the power of editing raw recorded data, I think I would have come to a more expressive result back then. Interesting musings, all set in motion by your image.
Buddy
Re: The color white
« Reply #13 on: June 13, 2017, 16:53:17 »
[pic]
I can realate to that. Easily. Instantly. Directly.
Very expressive. Structural room for thoughts.
Re: The color white
« Reply #14 on: June 14, 2017, 21:18:55 »
I like it! Very graphic and vivid
