Author Topic: Theme: Garden shots  (Read 13621 times)
Theme: Garden shots
« on: May 31, 2017, 22:22:55 »
two from the garden today, just because i can  ;D ;D ;D
Re: Theme: Garden shots
« Reply #1 on: May 31, 2017, 22:46:27 »
I like the web cradling the spider!
« Reply #2 on: May 31, 2017, 23:12:30 »
Nice images Hans - I agree the natural framing is great
« Reply #3 on: June 01, 2017, 00:20:30 »
Oh, how I like the bokeh of the first one, just because I can :)
« Reply #4 on: June 02, 2017, 15:41:47 »
Thanks Jakov! Me too. And i had to assume some pretty suspicious positions to make this shot. I tried to use the two background flowers as bokeh and for once it worked  ;D
« Reply #5 on: June 02, 2017, 15:43:06 »
Thanks Anthony and John. I would like to take credit for that, but really, we'd need to compliment the spider on this.
Did put some effort in lighting her and composing the shot as is. All handheld and flash in left hand.
Andrew
« Reply #6 on: June 02, 2017, 19:59:43 »
Good job with flash!
Andrew Iwanowski
« Reply #7 on: June 03, 2017, 09:07:35 »
Thank you Andrew.
PeterN
« Reply #8 on: June 08, 2017, 16:57:58 »
Spring's here. ;-)
Love the spider shot with all the spider and plant "legs".
Peter
« Reply #9 on: June 08, 2017, 21:10:47 »
Hans,
that would make a nice theme.
Gardens provide so many opportunities for photographers.
Would you mind changing it?
« Reply #10 on: June 09, 2017, 15:41:44 »
Hans,
Wouldn't mind at all, i'll give it a try. Might need some admin help though.
« Reply #11 on: June 09, 2017, 16:02:11 »
Unfortunately, that approach is only causing confusing. A Theme thread has to be opened in the proper forum and existing thread(s) moved there.
I'll edit this later tonight, but for now, just continue to post any garden pictures in this thread. Then the "cleaning-up" will be easier for the admins.
« Reply #12 on: June 09, 2017, 16:10:11 »
I agree Bjørn, next time i'll make sure to address this to the Admins first. I hadn't started the thread as a theme thread though, that idea only surfaced later. Sorry about this.
« Reply #13 on: June 09, 2017, 17:25:48 »
A member can start a new Theme thread, but only move their own posts into it. Thus sending a PM to a moderator first is a prudent measure if contemplating a change of an existing thread.
You should, however, be able to alter the topic title of your own thread; this is conducted in the first post.
« Reply #14 on: June 10, 2017, 07:55:34 »
Thanks!
