Author Topic: Looking for "Art lens" - Your thoughts on the new Meyer-Optik Trioplan lenses  (Read 11135 times)
Examples of the $200 Zenit 85/1.5.
Thanks to Erik it meters properly with its dedicated CPU :)
I am still going back and forth which camera I would like to use: Olympus PEN-F or D750. Getting an adapter should not be a problem.
Peter,
If you want large "bubbles" then you need a larger sensor than the Olympus or you need to use long focus or telephoto lenses. The size of the blurred light objects is determined by the physical size of the aperture or the apparent size and not the aperture ratio. If a 100~105mm lens gives the size blur you like you use the same lens on both the 35.9x24mm and 17.4 x 13.0mm. My 50/1.2 AIS on DX doesn't do much at all in terms of blurring backgrounds as the physical aperture is too small. Yes it blurs them but the things in the background are still quite recognizable as the blurs are small. My 85/2.0 AIS does more but at a greater shooting distance so a different perspective. Small subjects in close are easier to get blurred backgrounds with as the distance from the camera to the subject is short and the distance to the background can easily be far so the ratio favors background blur. Anyway take the format size into consideration while considering this. I recommend that larger FX format.
There are two things to consider here: the Bokeh or quality of the blurs and your preferences and the size. There are many factors to consider.
Jakov, those two are just marvellous!
Jakov, these two are very fine.
Thank you Erik and Thomas, much appreciated.
These images were taken during our Black Forrest workshop in September 2015, how time flies... :)
A comment from the side line: the blur circles are not controlled by camera format, but by absolute aperture and magnification. Thus the same lens, focused to the same distance, set to the same aperture, will make the same background blur. An easy prediction to verify experimentally.
I was about to say that, great that you did Bjorn!!
Jakov,
I really like the second photograph in this post!
simsurace
I was also to point this out, but then I was prevented by a general laziness. :D
You formulated it as simply and elegantly as possible.
This simple realization is very powerful, since it will tell you at any time how big your blur circles are.
You want to separate a subject from its background? You want your bokeh balls to be a certain size? By invoking this principle you will know in a heartbeat (or two) which lens and aperture to pick.
Simone Carlo Surace
suracephoto.com
I love the soap bubble images in this thread.
@Fons, which 35mm f/1.4 lens ist this?
Daniel, i cant remember either the 35mm f/1.4g, which i think it is or the 35mm f/1.4 ais, but concerning the bokeh they are similar, all shot wide open obviously,
It may be worth adding that the blur circle will appear proportionally bigger when a smaller format is used, in the same way a given lens appears proportionally "longer" (narrower angle of view) on smaller formats.
Jakov,
Thank you David :)
Yes, this issue can be perceived in that manner. However, due to different physical sizes of the sensors, different pixel dimensions, and so on, making a direct comparison to show the real size of the blur circles can be quite an undertaking. Knowing they indeed are equal sized can be helpful :D
Tom Hook
  • Tom
Big bubbles with a 300 2.8
What will change is a longer lens will often be selected for the larger format to have a similar angle of view and perspective. For example compare the blur circles one can achieve with a 70/2.8 lens on DX with those one can achieve with a 105/2.8 or 2.5 lens on FX. If larger blur circles are wanted try a 180/4.0 lens on 6x6/6x4.5 format.
**Anyway when I got an FX Nikon I got my beloved 105/2.5 Nikkor back.
There are many variables here but a basic priciple here is use a longer lens on a larger format to get bigger blur circles relative to the subject.
**I can only imagine the joy of owning a 105mm f/1.4 lens!
