Author Topic: Rorslett's Rule  (Read 8034 times)
OCD
  • Obsessive Corgi Disorder
Rorslett's Rule
« on: January 12, 2017, 03:13:45 »
Hello everybody, I really like the "Rorslett Rule."
So....if you're grabbing your three favorite prime lenses...what are they?  And for this topic....they need to adhere with the Rorslett Rule (or come reasonably close...we don't want to get too crazy with rules - for instance I like to use the 24mm/35mm/85mm f/1.8G's with my Nikon D750 - yeah...I know).
Just for fun!  And okay...include the camera you would use with those 3 lenses.
Re: Rorslett's Rule
« Reply #1 on: January 12, 2017, 04:20:31 »
"The permutations probably are endless. Consider carefully any upcoming trip to decide what to bring and why a given lens should be in that kit. Never ever take everything with you. That only leads to a mess."
So true  ;D
It all depends on what, and how, I intend to shoot (or have no idea  ;) ) .   I have MF sets for each camera as well as AF sets.  Am I flying or travelling by car.   I rarely shoot less than two cameras.   I am more likely to shoot MF on the Df and Sony more than my other cameras.   I normally take 2 or three lenses for each body and spread the FLs between the bodies.
Re: Rorslett's Rule
« Reply #2 on: January 12, 2017, 04:21:53 »
My current three favorite primes are AF-S 20/1.8G ED, AF 60/2.8 Micro and AF-S 105/2.8G ED VR Micro which I use for Normal and Close-up photography but not macro. All are Nikkor lenses.
Re: Rorslett's Rule
« Reply #3 on: January 12, 2017, 05:35:09 »
Zeiss 25/2, Summicron R 50/2 or Voigt 58/1.4, Nikkor 105/2.5 AI
if size & weight matter even more, then even less : Voigt 40/2 and Nikkor 105/2.5 AIS
And even less... I did whole trips with just one, but that depends on the mood. Tamron 45/1.8 may become the answer; in fact, anything between 40 and 58mm FL. 35mm is too wide for my taste for general shooting, even taking a reasonable amount of cropping.
AF Zooms limited to event shooting, in  which case they add lots of value
Re: Rorslett's Rule
« Reply #4 on: January 12, 2017, 05:49:20 »
I usually try to keep to one or two lenses - what I think I need + a backup in case I'm wrong, but if I need to pick three right now it would be nikkor 18mm/3.5, 35/1.4, 105/2.5 on Df. I have nothing in the area between 55 and 105.
chris dees
  • Amsterdam
Re: Rorslett's Rule
« Reply #5 on: January 12, 2017, 08:57:04 »
AF-lenses: 24/1.4G, 58/1.4G and 105/1.4E (300/4.0E as a close 4th)
MF-lenses: 20/3.5 UD, 35/1.4 N and 105/2.5 PC (all factory AI-d and chipped)
Chris Dees
Re: Rorslett's Rule
« Reply #6 on: January 12, 2017, 10:23:35 »
I'm all amazement the self-evident can be designated a 'Rule' and even more so that said Rule has my name attached to it ....
Basically it's about having specific tools for distinct tasks.
When I commenced photography many moons ago the setup was 24/2.8, 55/3.5 Micro, and the 105/2.5 Nikkors on an Nikon F, later F2. The "small" kit was 35/2 and 85/1.8 + an extension tube. Were I to require reach, the 200/4 came in handy in either alternative.
Permutations of that basic scheme is still in my mind when I arrange the gear for a given trip or assignment.
Re: Rorslett's Rule
« Reply #7 on: January 12, 2017, 10:45:51 »
this is almost the same as what I am using  :o :o :o
it's a common sense choice ::)
Bern
Re: Rorslett's Rule
« Reply #8 on: January 12, 2017, 11:08:47 »
I consider myself an amateur but then I maybe in the right track if a basic gear set will be the basis. Am using a 20mm 1.8G, 50mm 1.2ai-s or 1.8G and 105mm 2DC. Although, paired with a dx body. If needed it is supplemented/replaced with a 70 (or 80) - 200 f4 zoom on the long end. For the wide end, a 11-16 f2.8.
Keep shooting,
Bern
Re: Rorslett's Rule
« Reply #9 on: January 12, 2017, 13:23:42 »
This may be laziness on my part or adaptation but currently I only own 1 prime: 50 g 1.4  -and a couple rodenstocks but that´s another story :)-
   Even if it is out off the premises of the post or just bending it a little my basic set is the boring
    24-70 and
    80-200. ed
    Because I have 3 options I will add either 14-24, the 50 or a rodenstock as fancy strokes.
   There are plans to add a 85 1.4D -crossing my fingers- and to update the longer zoom with the 70-200 vrII
    That´s it.
John Koerner
Re: Rorslett's Rule
« Reply #10 on: January 12, 2017, 16:29:38 »
For nature hikes, to have all my bases covered, I always go with 2 bodies, 4 lenses.
Body 1 = the D500 with the 300mm f/2.8 VR II glued to it, which is carried on a RRS tripod over my shoulder (+/- the 2x TC III);
Body 2 = the D810 with the Voigtländer 125mm f/2.5 macro at the ready, which is carried on a holster at my hip;
(The 28mm f/2.8 AI-S is carried in a pouch, for wides, via interchange on my D810, as is the 50mm f/1.2 AI-S for portraits.)
Since I have to narrow it down to 3 lenses, here is my logic:
There is no way I would part with the 300mm + 2x TCIII on a nature hike. Its quality and flexibility make it mandatory for wildlife shooting.
There is no way I would part with the Voigtländer 125mm macro, as the ability to shoot macro on a nature hike is mandatory.
There is no way I would part with some kind of wide, or ultra-wide, on a hike for landscape. The 28mm AI-S is generally my go-to.
(The similar 20mm AI-S is sometimes substituted, but I prefer the handling and quality of the 28mm. I also have the 15mm AI-S, as an ultra-wide, but the flare is troublesome, the focus throw is a joke, plus the resulting image sharpness is less than the 28mm IMO)
Interestingly, for butterflies and such, I don't use my Voigtländer macro much anymore, since I can get virtually the same results with the 300mm VR II, with the added benefit of AF, and from farther away so as not to scare the subject. However, for stationary flowers, or still arthropods, where true 1:1 is necessary, and where I have the time to really compose, the Voigtländer macro, and its wonderful focus throw, are a joy to use. The ability to slowly and subtly focus are immersive.
I generally bring the AI-S 50mm f/1.2 for portrait shots, but since I have to be limited to 3 here, the 50mm could stay home and the Voigtländer could be used for portraits.
Jack
PS: For family get-togethers, or street shooting (where I don't need either a telephoto or a macro), I only bring 2 lenses in a small shoulder bag: the 50mm AI-S on my D810 with the 28mm AI-S available if I need a wide. I use this bag for light carry; it's pretty nice.
JohnBrew
Re: Rorslett's Rule
« Reply #11 on: January 12, 2017, 17:33:08 »
I would go for Zeiss 21/2.8, Zeiss 50 Makro and 105 2.5 Ai. A fairly compact kit even with the D810. For more compactness a Df or maybe an F-mount mirrorless (hey, I can hope, can't I?)
Re: Rorslett's Rule
« Reply #12 on: January 13, 2017, 10:52:38 »
On the Scotland NikonGear event I was shooting 6mm, 10.5mm and 16mm and it fit's the Rørslett Rule of doubling the focal length pretty closely  :o
Re: Rorslett's Rule
« Reply #13 on: January 13, 2017, 12:09:43 »
I concur with Erik's findings :D
My favorite kit would be 10.5/2.8, 20/1.8, 45P, and 135DC.
Extremely light and versatile on any format as long as it's full frame! :D
Re: Rorslett's Rule
« Reply #14 on: January 14, 2017, 05:21:53 »
In the early days, my travel kit was AI 20/3.5, AIS 55/2.8 micro and AIS 135/2.8. The spread is a bit more than the 2x ratio between lenses, but it enabled me to cover almost any situation - wide, standard, tele and macro. I find around 135-150mm is about as long as I can comfortably hand-hold (no VR). It is possible to hand-hold longer if the shutter speed is fast enough, but it's gets progressively harder to frame and focus accurately without some sort of support.
My ultra compact light-weight kit was AI 20/3.5, AIS 50/1.8 (Japan model) and E 100/2.8.
I usually shoot with some variation on this combination ...
