Author Topic: The two new Nikon lenses announced  (Read 2907 times)
Mikes
« on: October 19, 2016, 07:11:22 »
Mike Selby - Sydney
Re: The two new Nikon lenses announced
« Reply #1 on: October 19, 2016, 07:45:56 »
the 1.4m to 1.1m minimum focusing distance on the 70-200 is very useful! :o :o :o
stenrasmussen
« Reply #2 on: October 19, 2016, 08:06:04 »
And judging from the magnification increase at min focus distance the focus breathing "issue" has been seen to.
« Reply #3 on: October 19, 2016, 08:07:59 »
I will wait on this one.   Focus breathing is very bad at close focus on the current lens.  Was hoping for lighter. Sorry Sten, I'm slow.
Tom
stenrasmussen
« Reply #4 on: October 19, 2016, 08:11:16 »
A 0.21x magnification is the same as the newest Canon counterpart.
« Reply #5 on: October 19, 2016, 08:33:38 »
What a wonderful pair of lenses! I want and need them,,, ;)
« Reply #6 on: October 19, 2016, 21:53:59 »
The lens will focus up to 1.1m at all zoom settings, so the largest magnification factor should be achieved at the longest 200mm setting.
Based on the magification factor of x0.21 and the focus distance of 1.1m (1,100mm), the focal length at this setting is 157.776mm (if the calculation is correct).  The lens definitely uses focal length shortening method.  I'm not sure if that would lead to be breathing, though.
« Reply #7 on: October 19, 2016, 22:00:15 »
IMHO What matters is; Can I shoot a close up portrait with the lens without needing to crop half of the pixels away ;)
It is one of the tasks needed when facing a completely normal work situation with such a lens ;)
MILLIREHM
  • Vienna, Austria
« Reply #8 on: October 19, 2016, 22:42:43 »
A fourth PC lens was to be expected, 19mm instead of canons 17 mm though
Appears to be the first Nikon PC lens that enables aligning the tilt and shift axis without surgery
Wolfgang Rehm
« Reply #9 on: October 19, 2016, 22:47:08 »
The 19 would be a hot contender for the content of one's banking account hadn't it been for its darned price. Or perhaps the other way around. Not a lens one buys without a second consideration.
However, the specifications and samples are pretty convincing. A though choice awaits me.
