Author Topic: Irix 15/2.4  (Read 30204 times)
Re: Irix 15/2.4
« Reply #30 on: October 02, 2016, 21:16:28 »
Wow, I was about to comment about why Nikon can't make a super-wide prime like this, but they would never let a lens design get out the door with that kind of flare problem.  ...
The venerable Nikkor QDC 15 mm f/5.6 had a similar flare, although "cleaner" as it was just a narrow blue circle not red + green.
Probably reflections off edges of an element inside.
stenrasmussen
Re: Irix 15/2.4
« Reply #31 on: October 03, 2016, 00:39:52 »
For night time photography I actually like the Irix better than the Samyang.
Two Three shots from my test tour this evening:
jhinkey
Re: Irix 15/2.4
« Reply #32 on: October 03, 2016, 02:29:08 »
Yes, but this new lens was most-likely computer designed while the 15/5.6 is how many years (decades) old and was likely hand-designed in the late 60's early 70's?
stenrasmussen
Re: Irix 15/2.4
« Reply #33 on: October 03, 2016, 07:49:24 »
Here are two shots with the D500. As can be seen in the first image the lens is a little soft at the right side.
Will try my dealer's second copy.
stenrasmussen
Re: Irix 15/2.4
« Reply #34 on: October 03, 2016, 22:13:45 »
New copy is better.
Night shot at f/8, backed by the Df
aerobat
Re: Irix 15/2.4
« Reply #35 on: October 03, 2016, 22:18:08 »
Thanks for sharing your first impressions Sten.
I quite like the results. It certainly depends on usage.
What would your main usage be?
Daniel Diggelmann
stenrasmussen
Re: Irix 15/2.4
« Reply #36 on: October 05, 2016, 10:40:00 »
Night time shots is what my main intentions are. But as I now have a good copy I might expand on this. Here's a shot from this morning (f/4).
stenrasmussen
Re: Irix 15/2.4
« Reply #37 on: October 05, 2016, 11:05:08 »
A shot with the Irix on the D500.
Re: Irix 15/2.4
« Reply #38 on: October 05, 2016, 11:31:55 »
Sten, are there any improvements in flare performance with the second copy?
stenrasmussen
Re: Irix 15/2.4
« Reply #39 on: October 05, 2016, 15:01:23 »
Not that I can see.
Harald
    • Flickr
Re: Irix 15/2.4
« Reply #40 on: October 05, 2016, 15:26:48 »
Hi,
and your thoughts compared to the Samyang? :)
Harald
Some pictures on FLICKR
stenrasmussen
Re: Irix 15/2.4
« Reply #41 on: October 08, 2016, 10:08:51 »
Hi,
Harald
Except for the flare (which isn't a problem in most situations) I like it better than the Samyang. The lens is really at home on my D500. So I have a very good 22mm there.
Harald
    • Flickr
Re: Irix 15/2.4
« Reply #42 on: October 08, 2016, 15:34:57 »
Hi Sten,
so i will have a try the next time. :) Thanks for sharing your experience!
Harald
stenrasmussen
Re: Irix 15/2.4
« Reply #43 on: October 12, 2016, 10:57:30 »
A few more with this lens.
Re: Irix 15/2.4
« Reply #44 on: October 12, 2016, 11:15:10 »
Very nice samples Sten! Looks really good ;)
This is of cause also very dependent on PP - But It appears you also can see the high contrast and very saturated images from the lens as well as what we found at Photokina.
