Author Topic: Goodbye Full-Frame Cameras  (Read 33019 times)
Re: Goodbye Full-Frame Cameras
« Reply #90 on: January 11, 2017, 20:33:54 »
Yes, I save them all, many hundreds of thousands of them. It is a problem. I was hoping that with MF I can get by with short stacks, fewer layers. We will see.
The apparent DOF of a medium format image is usually less than an equivalent image in a smaller format (because you need higher magnification to frame the same subject), I'd expect you would need more layers to achieve a "sharp" image...
