Author Topic: Irix 15mm f/2.4  (Read 47193 times)
Re: Irix 15mm f/2.4
« Reply #15 on: September 10, 2016, 13:53:54 »
Irix has a photostream on flickr which shows some examples of sun in the frame as well as some night shots of the Milky way.
bjornthun
Re: Irix 15mm f/2.4
« Reply #16 on: September 10, 2016, 14:18:04 »
I've explained the reason why I stick to the DLSR more than enough.  But using a mirrorless body with the dedicated optical viewfinder on top of it may be a good option.
I mentiond no less than three DSLR wide angles lenses. The Canon 24/2.8 with a 58mm filter thread should fit the bill for "small" very well, particularly if you remove the lens hood, http://www.the-digital-picture.com/Reviews/Canon-EF-24mm-f-2.8-IS-USM-Lens-Review.aspx. I could have mentioned Pentax, which have done very well in creating readonably sized DSLR primes, albeit for APS-C.
We're not talking about DSLR vs mirrorless here, at all. Want big mirrorless wide angles, go check out Zeiss Batis 18/2.8 (77mm filter) and 25/2 (67mm filter). We're talking about lens programmes, and everyone seem to offer both big and small modern wide angles, except maybe Nikon, at this time.
BW
    • Børge Wahl-Photography
Re: Irix 15mm f/2.4
« Reply #17 on: September 10, 2016, 14:31:12 »
Thanks!
Re: Irix 15mm f/2.4
« Reply #18 on: September 10, 2016, 15:02:50 »
Not everyone can or wants to buy a camera body of an incompatible system (from what they are currently using) to be able to use a specific lens. Currently Nikon makes their compact primes with a f/1.8 maximum aperture which is a benefit compared to (say) f/2.8 but obviously it can be regarded a disadvantage as well. Personally I like Nikon's offerings but think they could add a few pancakes along the lines of the not too ancient 45/2.8 P.
Re: Irix 15mm f/2.4
« Reply #19 on: September 10, 2016, 15:20:59 »
One thing that I've found is that when using a big lens to photograph people, it helps greatly to act confidently and appear in a way that it seems like you belong there and know exactly what you're doing. When I photograph people on the street, I get all kinds of reactions from smile, a curious look, and also a "no apparent reaction". I ditch the shots where it seems the subject wouldn't have liked to be photographed and mostly keep those who take it with a sense of humor or are seemingly in their thoughts, or are interacting with others.
Small cameras and lenses are more inconspicuous, for sure. But confidence and a matter of fact approach (possibly a disarming smile) helps where a tense or nervous photographer might get an equally tense or frightened response from the subjects.
I find that practicing on the street gives me additional confidence to shoot documentary images at events.
bjornthun
Re: Irix 15mm f/2.4
« Reply #20 on: September 10, 2016, 15:23:38 »
I'm very aware of thar Ilkka, and I too stick to one system. My point was also that "small and unobtrusive" is not out of fashion, hence a reference to other manufacturers.
Time to head back to the topic, the IRIX 15/2.4.
The IRIX 15/2.4 seems very reasonably priced, and hopefully it will perform. Is there any hints yet on service and support on the Irix lens(es), in case that is needed?
Re: Irix 15mm f/2.4
« Reply #21 on: September 10, 2016, 15:35:27 »
I don't think any of 35, 28 or 24mm are superwides, maybe 24mm could be used as sperwide under circumstances, though.
Irix 15/2.4 is designed for Canon EF, NIkon F and Pentax K mount DSLRs.  It should be safe to assume that the discussion in this particular thread is based on the DSLR.
bjornthun
Re: Irix 15mm f/2.4
« Reply #22 on: September 10, 2016, 15:54:53 »
No, that is not safe to assume. The lens speed of f/2.4  alone makes the Irix 15/2.4 a prime candidate for adaption to Sony mirrorless, e.g. for night photography and video. This will be particularly true if Irix can deliver cosistent quality, as opposed to Samyang.
Re: Irix 15mm f/2.4
« Reply #23 on: September 10, 2016, 16:01:27 »
Please, continue discussion with focus (sic!) on the lens itself, not the platform to which it is attached.
Harald
    • Flickr
Re: Irix 15mm f/2.4
« Reply #24 on: September 10, 2016, 17:49:36 »
Hi,
Irix IS Samyang. ;) So i am hoping for a better quality Control. ;)
Harald
Harald
Some pictures on FLICKR
bjornthun
Re: Irix 15mm f/2.4
« Reply #25 on: September 10, 2016, 18:01:43 »
Hi,
Harald
Harald
Has that been confirmed? Samyang lenses wih proper quality control?
Re: Irix 15mm f/2.4
« Reply #26 on: September 10, 2016, 18:06:42 »
Harald, you stated that already once before in this thread with no details. Could you provide a source for this information? Thanks.
Harald
    • Flickr
Re: Irix 15mm f/2.4
« Reply #27 on: September 10, 2016, 18:31:45 »
Hi,
they are Made in Korea and both founders of Irix are the distributors for Walimex aka Samyang Poland and switzerland. It is hard to guess where it is produced. ;)
Harald
Re: Irix 15mm f/2.4
« Reply #28 on: September 10, 2016, 18:36:57 »
Hi,
Harald
you are so smart! you can be a detective :o :o :o
looks like irix is the new vivitar ::)
if this is indeed confirmed then i hope that their QC is helluva lot better this time.
Harald
    • Flickr
Re: Irix 15mm f/2.4
« Reply #29 on: September 10, 2016, 18:47:35 »
Hi,
i will Buy the 15mm because i know about the quality. I Love my 85mm 1.5 and had the 35 1.5. The Second One is very boring because it is nearly perfect. I sold it. ;)
I had a 14mm and it was Optically good, but focussing was a Nightmare. No Infinity stop and the Ring was not calibrated. So you had to guess... :( The Irix has a Gard Infinity stop and you can calibrate it by yourself. Waiting for Amazon to deliver.... ;) I also Hope for better quality Control: Half of the 14mm are crap and you can not repair them...
Harald
