Author Topic: Hood for Voigtländer 90mm f/3.5 APO-Lanthar SL-II /Nikon  (Read 10560 times)
DanAa
« on: August 29, 2016, 10:52:58 »
Hi, what hood would you recommend for the Voigtländer 90mm f/3.5 APO-Lanthar SL-II / Nikon. I have lost the small original one, and I need to find a new one.
Re: Hood for Voigtländer 90mm f/3.5 APO-Lanthar SL-II /Nikon
« Reply #1 on: August 29, 2016, 11:41:58 »
I prefer to use the Nikon HN-7 on the 90mm.
« Reply #2 on: August 29, 2016, 11:47:14 »
A pity you lost it because that hood is very versatile and can serve on other lenses as well, including the Coastal Optics 60/4 APO, UV-Nikkor 105/4.5, and the 45/2.8 Ai-P Nikkor.
The HN-35 (for 45/2.8 ) will work, but is very elusive and/or expensive. You can easily make a nice hood yourself, though, by combining a K-4 ring with a 52 > 3940.5 or similar step-down ring. If necessary, add a reversing ring 52-52 mm to get the thread genders lined up correctly. When the pieces come together and match, seal the joins with a few drops of epoxy glue.
The simplest and cheapest solution is just using a K-5 directly.
« Reply #3 on: August 29, 2016, 11:59:35 »
I have bought for my 90mm apo lanthar a 49mm hood like the one in the link with cap. I don't remember exactly where from, but through ebay. probably from China.
Ridiculously cheap.
http://www.ebay.co.uk/itm/49mm-metal-tilted-vented-Lens-Hood-Shade-Lens-cap-For-Leica-M-Contax-Fujifilm-/142051693511?hash=item2112f0d3c7:g:oLUAAOSwpDdVZzsr
« Reply #4 on: August 29, 2016, 12:51:24 »
If you have the designated close-up attachment for the 90 APO, it has 39 mm threads. Thus making your own hood by combining K-4 with a 52->39 mm step ring is highly favourable.
(in the earlier post I said 52-40.5 or similar step ring, but although most combinations will work, only something ending with 39 mm (female) threads  will directly support the attachment)
DanAa
« Reply #5 on: August 29, 2016, 12:56:37 »
I have to do an careful survey in all my boxes and drawers  ....
« Reply #6 on: August 29, 2016, 12:56:56 »
Has the SL I  a different filter thread?  The SL II has a 52mm.
DanAa
« Reply #7 on: August 29, 2016, 12:57:31 »
Thanks for all your comments.
« Reply #8 on: August 29, 2016, 13:02:53 »
Probably not. The SL.2 is 52mm. However, the dedicated close-up attachment is 39 mm and mounts via the special lens hood accompanying the lens. Put a short 39 mm extension ring on top of that to make a nifty little hood also for the close-ups.
« Reply #9 on: August 29, 2016, 13:29:08 »
Shame that Cosina apparently is reluctant to provide the specs of discontinued items...
bjornthun
« Reply #10 on: August 29, 2016, 13:30:26 »
52mm to 39mm step down rings can be found on eBay. Would that do the trick as a make shift lens hood for the CV 90/3.5 II?
« Reply #11 on: August 29, 2016, 13:39:13 »
Partially. You need to extend the step ring a little as well, thus combining a K-4 or similar  as spacer is perfect.
« Reply #12 on: August 29, 2016, 13:47:00 »
If the need of the extension is to narrower the opening of the hood, 52-37mm step-down ring by Kenko might work?
« Reply #13 on: August 29, 2016, 13:54:37 »
Nope. You need a spacer to push the step-down ring sufficiently forward so it cuts stray light from the side. Plus as already stated, the dedicated close-up attachment is 39 mm thread.
« Reply #14 on: August 29, 2016, 14:13:52 »
Ah, the closeup lens...
