Author Topic: [Rumor] D760 for Photokina???  (Read 10179 times)
« on: August 28, 2016, 13:51:15 »
http://thenewcamera.com/nikon-d760-coming-on-photokina-2016/
A 24-MP-D750-spinoff with Exspeed 5 and D5 AF could smoke them all for small change!
Re: [Rumor] D760 for Photokina???
« Reply #1 on: August 28, 2016, 17:10:13 »
Strange.  D750 was released only two years ago.  Considering the life cycle of the "midrange" Nikon, D610 should be replaced before D750 would.
aerobat
« Reply #2 on: August 28, 2016, 17:40:20 »
The D750 is a very good camera for only little more than a D610. It would perhaps make sense to rethink the lineup and offer only D760 at a competitive price.
We don't need so many models. I'm highly interested in a D760.
Daniel Diggelmann
« Reply #3 on: August 28, 2016, 18:18:12 »
Do not forget it is a rumor.
It could replace the 610 and the 750.
« Reply #4 on: August 28, 2016, 18:53:38 »
I also think the co-existence of D7X0 and D6X0 makes no sense anymore.  So, if D760 means the discontinuation of D6X0 series along with the renewal of D750, that makes more sense.
« Reply #5 on: August 28, 2016, 19:38:40 »
The D610 has a $500.00 (USD) instant savings at B&H Photo, N.Y. while the D750 has a $300.00 (USD) instant savings at B&H Photo. There are other instant savings in effect.
« Reply #6 on: August 28, 2016, 23:50:24 »
Seems unlikely Nikon would release a new FX camera with EXPEED5 and D5 AF so soon after the D5 and D500. Nikon usually waits at least a year or two so early adopters who want/need these features are forced to buy the more expensive cameras. Only then does it start to trickle down to lesser models. As others have pointed out, the D750 is still mid-cycle.
As for D610 and D750 ... I wonder if the D6xx series might move towards the entry level market - such as removing AI metering and screwdriver AF? This would create separation from the D7xx series and might attract low-end buyers to FX?
« Reply #7 on: August 29, 2016, 00:03:40 »
Roland: Highly unlikely, yes. We will see. They got the D3400 right ....
« Reply #8 on: August 29, 2016, 00:21:00 »
I don't see them releasing a D750 successor without a new sensor.  New AF alone wouldnt be enough for them to boast about on such a popular and profitabe model.
« Reply #9 on: August 29, 2016, 03:35:51 »
The AF sensor unit in D5/500 is much larger than that of D750.  If D760 uses the same sensor, it should be as tall as D810.
The compactness is an important design aspect of D750.  Its width of 140.5mm (0.5mm narrower than D610) had been targeted even before they started designing it, according to an interview to its design team.  I don't think D760 would be any larger.
D500 is almost as tall as D750 because it is a DX body.  The length between the bottom of the body and the lowest part of the mount is longer on D500.
« Reply #10 on: August 29, 2016, 13:46:29 »
I also don't think Multi-CAM 20k will find itself in any successor of the compact FX DSLRs (D610, Df or D750); the D750's scaled down version of the Multi CAM 3500 is more likely.
I would, however, expect to see Multi-CAM 20k in the D810's successor.
« Reply #11 on: August 29, 2016, 13:51:57 »
Yes, that would be necessary especially if the D810's successor would use the derivative of 42MP sensor used in A7RII.
Pistnbroke
« Reply #12 on: August 31, 2016, 08:17:32 »
I wont buy a 750 as it still has the LPF in it ....Tale that out I might be interested
« Reply #13 on: August 31, 2016, 08:21:46 »
Do not know LPF?
Olivier
  • Olivier Anthony
« Reply #14 on: August 31, 2016, 09:07:55 »
low pass filter, maybe?
