Author Topic: Df 2.0-Looking in to the crystal ball  (Read 13830 times)
BW
    • Børge Wahl-Photography
« on: August 25, 2016, 10:42:55 »
Not that my present Df has reached the end of its cycle, but I was wondering what other users might think about the possibility of an upgraded version of the little gem? To me it has served well as a camera that is always by my side without getting in my way. Are we seeing a Df 2.0 during the coming year?
Re: Df 2.0-Looking in to the crystal ball
« Reply #1 on: August 25, 2016, 10:54:25 »
D5 sensor first thing comes to mind, better quality build, i may hope.
« Reply #2 on: August 25, 2016, 11:11:42 »
Difficult to tell an upgraded version will come. Nikon's 100th anniversary in 2017 is mentioned as a possibility.  Perhaps mirrorless?
« Reply #3 on: August 25, 2016, 11:14:27 »
I want:
1: no rear LCD (fine-tune done in tethered computer)
2: meter on the top instead of the useless remaining shots/exposure info
3: no screw-drive AF
4: D750 class AF module
5: old-size F mount (like the one on the F3 and earlier)
6: as usual, fold-able aperture coupling tab
7: STOP-DOWN METERING
8: smaller or thinner
9: all-brass chassis
10: true mirror lock-up
basically an F3 interface :o :o :o
not sure if this if this is how Nikon's marketing feels as well ::)
Nikon should actually slap their marketing division for a lack of vision and touch with the consumers.
BW
« Reply #4 on: August 25, 2016, 11:22:42 »
The size and build quality of the current Df is in my opinion pretty decent. Why mine haven't broken down yet, is a mystery? It has never seen a rain cover and has spent countless hours of rain, sleet, snow, moisture and fluctuating temperatures. I never intend to treat a camera as a baby and the Df has not given me a reason to do so, yet. The front wheel has to change though. I have glued some Lego to it so could build a nob that my index finger can operate.  I have lost the camera on the ground twice, but it haven't affected the the output of the camera.
« Reply #5 on: August 25, 2016, 11:26:04 »
My eyepiece gets full of water when it rains, wearing it with the lens pointing down.
BW
« Reply #6 on: August 25, 2016, 11:27:20 »
I want:
You forgot the a decent manual focus screen. I dont agree with nr 8 and 9, but who's aiming for consensus ;)
BW
« Reply #7 on: August 25, 2016, 11:29:58 »
I have used the magnifying eyepiece which protrudes from the camera. In combination with the DK-19 rubber it has been ok.
« Reply #8 on: August 25, 2016, 11:36:36 »
If you want decent AF take the D5/D500 module
BW
« Reply #9 on: August 25, 2016, 11:37:50 »
If it is anniversary edition, the price might get ugly. If it mirrorless I dont want to be the test pilot. Then, it may take years (read: several versions) until we see a viable product.
Thomas Stellwag
« Reply #10 on: August 25, 2016, 14:27:57 »
....I do not want a anniversary edition with candle light holders....
@ richardHaw:  if you say: no motor for AF lenses it is pointing towards total MF use
then saying a better AF module?  I do not get what is your point, except saving some 10gr.
on my DF very often are 3 AF(D) lenses used:
 1.4/ 85mm, 2.0/ 105mm and 2.8/ 180mm
why should a new Df exclude these good lenses?
easy changeable screen in the viewfinder would be nice
...and for the whole range:  reduction of types of accus
Thomas Stellwag
abergon
    • Portfolio
« Reply #11 on: August 25, 2016, 14:46:03 »
My wish list:
1 - First and foremost I hope they will keep the ability to mount pre-AI lenses;
2 - A D5 sensor would obviously be very nice :-)
3 - A split-screen for focusing;
4 - Improved ergonomics, like a better solution for the front wheel;
For the rest, the Df is basically what I expect from a digital camera, so I'll be conservative and ask for a minimum of changes.
dslater
« Reply #12 on: August 25, 2016, 15:42:19 »
I want:
Why in the world would you want to remove the screw-drive AF? There are still plenty of wonderful AF-D lenses out there that benefit from this feature.
dslater
« Reply #13 on: August 25, 2016, 15:43:27 »
Also, are there any numbers of sales, revenue & profit margin for the Df? If it didn't make a profit, I wouldn't hold my breath for a version 2.0
« Reply #14 on: August 25, 2016, 15:46:05 »
For me:-
1. The sensor, AF, and flash systems of the new D5 - much like the D700 had the equivalent smarts from the D3 - now justifiable given the large % price increase of the D5 over the D4S
2. The build and ruggedness of the D700, and its frame rate or better; not fussed if the weight goes up a little, so long as it is "good weight".
3. Improved focussing screens to support MF lenses, which are designed for ease of installation - like the old FM2 and FE2 were designed.
4. Continued support for pre-AI lenses, including stop down metering
5. Shift the memory card door to the hand grip - away from the bottom
6. Dual QD cards
7. Use the same battery as for the D810 - this implies a larger hand grip - which I would welcome.
8. Replace the wretched front control knob with a standard control wheel integrated into the hand grip.
9. Include a voice recorder to support in-field documentation and audio note taking
10. Articulate the rear LCD - similar to the Olympus OMD E-M1, and also make it touch sensitive.
11. Keep the rest
I quite like the look of the current Df and most of its controls but I don't believe for one moment that it has to look exactly like a FM2 or FM-3A or any other film camera.  For goodness sake it is a digital SLR that should be the best blend of traditional and electronic controls with a UI for stills use - but in designing a Df Mk II Nikon doesn't have to be a total design slave to the past either.
