Author Topic: dismantling the Nikkor 200mm f/4 Ai lens!!!  (Read 5243 times)
« on: July 24, 2016, 15:17:31 »
https://richardhaw.com/2016/07/24/nikkor-200mm-f4-kai/
Just uploaded! I hope that you like it! :o :o :o
don't we have a thread for this lens? I wonder where that went...
FGAng
  • Mixing the old and the new Nikkors
Re: dismantling the Nikkor 200mm f/4 Ai lens!!!
« Reply #1 on: July 29, 2016, 02:43:16 »
Always amazed with your work Rick!  I will work on my copy of the K lens, but not just yet.
« Reply #2 on: July 29, 2016, 05:59:43 »
Hello, Asher. That was writen for you and another guy who requested. there was also another person asking for focus calibration a long time ago, i think he found out for himself :o :o :o
« Reply #3 on: July 29, 2016, 08:53:35 »
Thanks for this extended review, Richard.
You wrote something about the 50mm f/1.4 Nikkor-S Auto on your blog, and couldn't find it here. The focus-ring of my lens is not working any more, and I understood the method to get it fixed is to remove a front ring?
« Reply #4 on: July 29, 2016, 08:59:55 »
https://richardhaw.com/2016/01/23/project-nikkor-s-50mm-f1-4/
Hello, John. There's the link. :o :o :o I wrote that for somebody who shoots concerts with that lens ::)
As common with most Nikkors of the same vintage/era, this lens is best worked from the front.
« Reply #5 on: July 29, 2016, 09:05:34 »
Thank you Richard. I have already read it. As the front ring won't move at all, I seem to be stuck.
« Reply #6 on: July 29, 2016, 09:18:55 »
Hello, John. Which front ring are you talking about? :o :o :o The one with the numbers or the chrome front barrel?
You may want to soften up what was used to glue it ::)
« Reply #7 on: July 29, 2016, 10:19:23 »
The ring connected to the focusring, in order to get to the screws to try to get it focus again.
« Reply #8 on: July 29, 2016, 10:25:01 »
This thing? :o :o :o
You may need to put plenty of alcohol to loosen this part.  ::)
I also use an old rubber flip flop and bored a hole in the center and use it to grip that ring.
that ring is flimsy by the way and if you warped it, you will not get this lens to focus smoothly
« Reply #9 on: July 29, 2016, 10:59:26 »
Thanks Richard.  I will try the loads of alcohol  ;)
« Reply #10 on: July 29, 2016, 11:04:19 »
or use a flip flop :o :o :o
chris dees
  • Amsterdam
« Reply #11 on: July 29, 2016, 13:09:36 »
Not drink it!  ;D :P
Chris Dees
« Reply #12 on: July 29, 2016, 13:25:38 »
:)  I 'll rubberize it first with a flip flop
FGAng
« Reply #13 on: July 29, 2016, 14:04:15 »
Yes I know that and I thank you. Just that I'm now obsessed with the 43-86 and the 36-72...
Will work on this later.
