Author Topic: Projection lenses  (Read 186249 times)
Re: Projection lenses
« Reply #135 on: April 11, 2017, 10:21:10 »
The Hermagis 80 photos are amazing!!! I want one of those.
One of my fav lenses Andrea, very unique Petzval bokeh it has. With a bit patience, it
can be sourced, although prices for original ones have gone up quite a bit. I'll let you
know when I see one...
« Reply #137 on: April 11, 2017, 11:15:26 »
You mean this?
http://www.ebay.com/itm/Som-Hermagis-Cinema-lens-F-80-mm-602942-/401299042683?hash=item5d6f49717b:g:YeIAAOSwTM5Y5HTk
No, this is a much later one, I mean the original brass Hermagis projection lenses not SOM. It might still be Petzval scheme.
SOM Berthiot ("Société d'Optique et de Mécanique"), founded 1857, bought teh muck older company HERMAGIS, founded 1845, in 1934 and integrated them into their business, so Hermagis disappeared and was just used as a brand name by them later.
« Reply #138 on: April 11, 2017, 23:57:31 »
I see.  Thanks for the clarification!  I've only known Som Bertiot only for the c- or d- mount cine lenses.
« Reply #139 on: April 21, 2017, 17:39:18 »
Friend of mine and old style surrealistic Painter was my model yesterday in the Park,
ist just so happened out of coincidence...
...and I was painting him using my camera and an old Philips radiographic 1.5/100mm projection lens ;-)
« Reply #140 on: April 21, 2017, 19:26:16 »
Very Impressive Klaus.  That first shot is really a beauty of a lucky strike ;)
« Reply #141 on: April 21, 2017, 21:12:55 »
Thanks! Well, that was "designed", as I noticed that this lens has this effect due to the very strong
front lens curvature and working w/o sun shade against the sun helps to create such effects ;-)
« Reply #142 on: April 22, 2017, 07:39:21 »
It is a fantastic effect.  What camera or sensor size?
« Reply #143 on: April 22, 2017, 07:46:27 »
Klaus, the first image rocks!  The artist should be delighted with this surreal effect.  :D
« Reply #144 on: April 22, 2017, 10:00:20 »
For a minute i thought this was Bjørn  :)
« Reply #145 on: April 22, 2017, 13:05:08 »
We meet tomorrow to look at all shots, but I also guess he will really like it! ;-)
« Reply #146 on: April 22, 2017, 13:06:21 »
Thanks! I used my Panasonic Lumix GH4
You crack me up Fons! :-)
« Reply #147 on: May 04, 2017, 01:39:24 »
TTH Micro Circuit projection lens f4/114mm (apochromatic lens resolving up to 350lpm on an 84mm image circle)
« Reply #148 on: August 08, 2017, 23:30:45 »
At the flower shop with f2.8 30mm Micro Projection lens, no aperture
« Reply #149 on: August 10, 2017, 19:09:12 »
Here now using a f1.6/100mm VISIONAR with and without Speedbooster
Without:
with:
