Author Topic: Fisheye-NIKKOR 6mm f/1.4  (Read 6296 times)
RonVol
« on: June 24, 2016, 23:09:25 »
Here's a lens that, until yesterday, I had no idea existed.
Fisheye-NIKKOR 6mm f/1.4 with serial #901401.
The lens is on display at the National Museum of Nature and Science, Tokyo.
Apparently it was designed for capturing images of auroras and probably cloud patterns too.
I've asked a friend in Tokyo if he could visit the museum to see if more info might be available.
Image is by Itoshiki Ku.
Re: Fisheye-NIKKOR 6mm f/1.4
« Reply #1 on: June 24, 2016, 23:48:58 »
Now, that is a surprise ... any idea whether it had an F-mount?
« Reply #2 on: June 24, 2016, 23:53:43 »
Here's the story about the upper atmosphere observation using this very 6mm/f1.4 fisheye.
http://www.nikon.com/about/technology/field/aurora/index.htm
RonVol
« Reply #3 on: June 25, 2016, 00:03:33 »
Thanks for that link Akira  :)
« Reply #4 on: June 25, 2016, 00:05:38 »
You are welcome.  Hope you enjoy it!  :)
RonVol
« Reply #5 on: June 25, 2016, 00:39:14 »
A little bit of research has yielded this series of images, examples of what the lens/camera combination is used for.
RonVol
« Reply #6 on: June 25, 2016, 00:40:10 »
...................and some tech specs.
RonVol
« Reply #7 on: June 25, 2016, 00:43:07 »
.............and this from the Nikon site that Akira provided the link to.
You can see the plastic dome that the lens is housed in.
RonVol
« Reply #8 on: June 25, 2016, 00:45:31 »
Based on the images above; it's not an F-mount.
« Reply #9 on: June 25, 2016, 01:13:08 »
Ron, thanks for the additional info.  512x512 pixel is pretty dense.  :D  I wonder if you need to "cool" the CCD in Antarctica?   ::)
RonVol
« Reply #10 on: June 25, 2016, 01:32:30 »
Here's a shot showing 2 of these lenses being used in a configuration from 2002.
So we now know that at least 2 of these lenses exist and were around as far back as 1996.
The configuration is called the CRL-ASI, here's a description;
As an objective lens, the CRL-ASI has a fish-eye lens with a 6mm focal length and F1.4 made by Nikon Technologies Inc. It is capable of a 180deg all-sky field of view, which enables it to observe a wide area within a radius of several hundreds km range around the observation point. Rays of light pass through the objective lens and then through a collimator lens to become a collimated beam, through an interference filter for spectral separation and is then focused on a CCD device unit. This optic system is based on the all-sky auroral imager developed by the National Institute of Polar Research (NIPR) in 1996 as well as on the airglow-observation-imager developed later at Kyoto University. Interference filters are mounted on the five-channel filter turrets, enabling observation at any of five channel-selected wave-lengths. The telecentric lens has a focus-adjusting mechanism to enable the capture of high-resolution images. The detector unit is a cooled camera with 512 X 512-pixel back illuminated CCD, achieving high-sensitivity and convenient in handling.
chris dees
  • Amsterdam
« Reply #11 on: June 25, 2016, 09:06:16 »
Just send it to Erik.  :)
Chris Dees
« Reply #12 on: June 26, 2016, 11:55:09 »
There have been very similar lenses made by other vendors for similat applications (often military), I've seen them sold quite a few times. Image circle is rather small though, although the back focal length is rather long (due to the required filter wheel).
First Nikon I ever saw, thanks for sharing!
« Reply #13 on: June 26, 2016, 11:59:33 »
The impressive speed might be easier to achieve when the image circle is small.
The long "tail" of the lens might include a built-in relay system.
A pity these lenses are so elusive, should be fun to experiment with.
RonVol
« Reply #14 on: June 27, 2016, 06:35:09 »
Thanks for the info and also thanks for the positive feedback  :)
