Author Topic: Fisheye-NIKKOR 6mm f/1.4  (Read 6273 times)
RonVol
Re: Fisheye-NIKKOR 6mm f/1.4
« Reply #15 on: June 27, 2016, 06:39:07 »
The impressive speed might be easier to achieve when the image circle is small.
The lens appears to be around the same physical size as the f/2.8.
I'm wondering if in fact it's the 6mm f/2.8 but , because of the reduced image area, they've gained an increase in speed.
Would this be possible?
« Reply #16 on: June 27, 2016, 09:13:58 »
No.
It's the light gathering that counts, not what is delivered at the rear end. The size of the entrance pupil is the important parameter and this is set by the lens design.
RonVol
« Reply #17 on: June 27, 2016, 09:29:20 »
No.
Ok, thanks...................I guess that makes sense.
« Reply #18 on: June 27, 2016, 11:04:27 »
The long "tail" of the lens might include a built-in relay system.
A pity these lenses are so elusive, should be fun to experiment with.
IF it doesn't have NIKON written on it, I could help. Let me know.... ;-)
« Reply #19 on: June 27, 2016, 11:09:19 »
I'm all ears, Klaus.
« Reply #20 on: June 27, 2016, 18:16:20 »
