Author Topic: FM-2n and Diopter correction  (Read 8053 times)
« on: June 15, 2016, 17:51:59 »
Aerobat's FM-2n I bought is still in the post but it already
got me thinking: How will I shoot it?
I bought some prepaid non reusable chemical sensors to do some
whacky experimental stuff with them. I also have some very decent
MF glass to draw light structures with photons. Plus a lot of not so decent...
Yet it just crossed my mind that my biological light sensors
are seriously challenged and the FM-2 might not have any means
to compensate for that but insanely expensive screw in lenses.
Help! Please...
Re: FM-2n and Diopter correction
« Reply #1 on: June 15, 2016, 17:59:54 »
You might need diopter lenses for the ocular, Frank. If I recall correctly, the finder is set for -1 dioptri which is the Japanese norm. It has no further means of direct adjustment.
I just checked with a pristine FM2 sitting in my cupboard and I definitively need my reading glasses to see anything in the otherwise nice, bright finder. Do put an eyecup on the ocular to save your spectacles from being scratched.
charlie
« Reply #2 on: June 15, 2016, 20:00:06 »
Provia 400, so sad to see that one go.
« Reply #3 on: June 15, 2016, 20:00:30 »
I am +2.5 so do I need a +3.5 correction lens then? Or do I need a screw in rubber plus reading glasses?
screwin'rubber ..... hahahaha
« Reply #4 on: June 15, 2016, 20:07:38 »
Try without glasses first.
The reason they put in -1 as a standard is the need for seeing both finder information, and ground-glass image, reasonably sharp at the same time. Thus the inherent focus of the system is at 1 m, explaining the -1 dioptre setting. People have different ability to accommodate their eye sight thus a practice test is recommended before you commence the screwing-in of any attachment lens(es).
« Reply #5 on: June 15, 2016, 21:00:59 »
And where do I get the rubber and the correctional glass elements ... just in case ...
« Reply #6 on: June 15, 2016, 22:07:01 »
Rubber eye cup is standard Nikon accessory - ask your dealer. They should also be able to supply the dioptre attachments for the ocular.
« Reply #7 on: June 16, 2016, 06:16:10 »
Bjørn's advice to try in person is highly advised, because Nikon has a peculiar naming convention for their eyepiece diopters.  The diopters are named for the net camera finder  +  diopter value, not for the diopter value of the lens by itself.  If you want to shoot using your spectacles, by all means test while wearing them.
Matthew Currie
« Reply #8 on: June 16, 2016, 07:08:23 »
I'd definitely try it out first.  I am comfortable reading at 2.5 to 3.5,  but find a +1 diopter about right on a Nikon viewfinder.  Stacking two +1's on top of each other is too much.  At one point I ordered a +1 for my F3HP, and KEH accidentally included a +3 along with it, and it's totally unusable.
Figure what diopter you'd need to see a computer screen from a meter away, and that's pretty close to what you need in a correction lens.
I've gotten a couple of these things used from KEH.com.  Some of the newer diopter rings have a rubber rim that's a bit heavier than it used to be.  Nikon's own chart is confusing.  There are actually only two thread sizes made - one for the earlier Nikon Photomics and Nikkormats, through the non-HP F3, and one for the HP F3 and subsequent models with threaded eyepieces.  Any other differences are in ring design, not threads.
« Reply #9 on: June 16, 2016, 10:29:50 »
Confusing. I prefer NOT to wear glasses because I cannot see anything with them except in the very near field
Computer Screen 1 Meter is roughly +1.5 to +2.0
« Reply #10 on: June 16, 2016, 16:31:39 »
In theory, the Nikon "0" diopter or the Nikon "1" diopter should accommodate your vision.
Eddie Draaisma
« Reply #11 on: June 16, 2016, 16:57:13 »
My eyesight is still good at large distances, but not at the 1m virtual finder distance (-1 diopter) anymore. For the old Nikons without built-in diopter adjustment (including a FM-2n) I bought +1 diopter screw-in eyepieces from EBay. Problem solved. Note that the diopters for the Fujifilm X-Pro1 (still available as new) will fit the FM-2n.
abergon
    • Portfolio
« Reply #12 on: June 16, 2016, 19:29:30 »
There is also the nuclear option: laser eye surgery. I am writing from personal experience.
« Reply #13 on: June 16, 2016, 19:42:04 »
Nono. It is reading glasses. And it is a non laserable aneurism. Laser simply is no solution in my case.
But. I ordered a +1 Nikon Diopter brand new from Japan at 20 Euros incl. Shipping.
I studied the Nikon documentation on that topic on service nikoneurope eu
hope all will be worth the effort in the end.
Eddie Draaisma
« Reply #14 on: June 16, 2016, 23:52:18 »
The +1 should work for you if your eyesight is (still) good at infinity.
You will find out that on the FM2 the 35/1.4Ais gives the impression of a much bigger lens. No (MD11/MD12) motordrive??
