Author Topic: Cleaning the 1000mm Reflex-Nikkor  (Read 3349 times)
Edgy01
« on: May 30, 2016, 02:49:38 »
Have had my 1000mm Reflex-Nikkor for a number of years.  I have also used my late model 2X telextender on it quite successfully.  But I have noticed that I have some dust which seems to get in easily with this design.
Is there a simple (or relatively simple) way to get inside to clean elements, or the mirrors?  Which lenses or mirrors are the more influential upon imagery quality if dusty?
TIA,
Dan
dslater
Re: Cleaning the 1000mm Reflex-Nikkor
« Reply #1 on: May 30, 2016, 16:11:27 »
Just remember, unlike the coatings on lenses, the aluminum coating on the mirrors is extremely fragile and easily scratched. If I were you, I would limit cleaning of the mirror surfaces to nothing more than blown air, or possibly a very soft brush if absolutely necessary.
« Reply #2 on: May 31, 2016, 15:52:12 »
Good Advice!
« Reply #3 on: May 31, 2016, 16:08:27 »
http://lenscleanservice.com/index.php?QBlog-20151118-3
too give you an idea ::)
a different lens, but construction should be the same. :o :o :o
have you tried the vacuum cleaner approach?
Edgy01
« Reply #4 on: May 31, 2016, 23:01:42 »
I have not tried any methods yet.  I can see how the design can literally suck dust laden air into the mechanism.  I think I'll have to take the front mirror off to gain access to blow off the surfaces, o to vacuum out the internal workings.
Thanks
Dan
Netr
« Reply #5 on: March 26, 2021, 00:41:15 »
Hello. I have just received a very nice condition Nikkor 1000mm f/11 lens. It came without the focusing handle.
Does anyone know what thread is used for the focusing handle?  It is clearly less than the 1/4" tripod mount, but i don't have any suitable small bolts to do trial and error with.
Thanks, Ross
Netr
« Reply #6 on: May 13, 2021, 01:40:51 »
Replying to my own question.  A 5/32" bolt will fit roughly, but the thread spacing seems wrong.  A 4mm bolt seems to screw in smoothly, and that is what I will use.
These old lenses take on a new lease of life with the ability to use focus peaking and the simplicity of increasing the contrast, either at the time of capture or in post-processing. Still needs a tripod.
paul hofseth
« Reply #7 on: May 13, 2021, 09:24:33 »
I would be extremely careful not to dislodge are anything in a catadioptric lens; since the light path is folded 3 times tolerances   must be 3 times more carefully observed
p.
