Author Topic: Hello from Holland  (Read 5619 times)
Laagwater
    • Laagwater Fotografie
Hello from Holland
« on: May 16, 2016, 09:15:33 »
My name is Edwin and i'm so glad that i found this site.
When i was looking for an old Nikon lens in the past, i always looked for what Björn had to say about the lens.
When i wanted some specific data of a lens I found it at Rolands Nikon pages.
When i found both names here on the forum i knew there must be a nikon soul behind this site.
I have used many Nikon cameras in the past, but nowadays i mostly shoot with an A7.
Reason is the ability to use many old lenses from different companies. Still using and loving my Nikkors and filmcameras from Nikon nevertheless.
I'm not a writer myself, but will enjoy this community
warmest Regards,
Edwin
Re: Hello from Holland
« Reply #1 on: May 16, 2016, 09:27:14 »
Welcome, Edwin. We all would love the occasional picture posted here, they tell more than a 1000 words :-)
« Reply #2 on: May 16, 2016, 09:27:52 »
Hi, welcome to Nikon Gear  :D You'll find here a quite interesting team !!!
« Reply #3 on: May 16, 2016, 09:48:12 »
We have a great Admin Team but that alone would be like an empty bus with competent drivers.
The site lives by the free spirit of the people posting here.
So YOUR words and pictures will be greatly appreciated!
« Reply #4 on: May 16, 2016, 10:40:18 »
Welcome to Nikongear. I am a passenger on the bus with some competent driver or some sorts.
Olivier
  • Olivier Anthony
« Reply #5 on: May 16, 2016, 10:43:26 »
Welcome Edwin
I usually sleep in the back of the bus. That is also where they keep the food...
no need to write, just show pictures!
« Reply #6 on: May 16, 2016, 11:12:32 »
welkom
« Reply #7 on: May 16, 2016, 12:17:14 »
hm, technically this is against the forum guidelines. Try to post a picture only and the software rejects it.
A workaround is you post the technicalities: camera, lens, time, aperture, GPS coordinates or the like
charlie
« Reply #8 on: May 16, 2016, 21:59:16 »
I don't think its against any guidelines per se, just a software coding restriction. A simple keystroke such as - should bypass this 'feature' if need be, or linking to a picture instead of uploading it and you should be able to get away without words, if that is the aim.
Welcome, Edwin.
Olivier
  • Olivier Anthony
« Reply #9 on: May 16, 2016, 22:12:34 »
« Reply #10 on: May 16, 2016, 22:14:10 »
Charlie is correct. The forum software does not allow an empty post. As would arise if an image is attached. However, inserting the image via the IMG tags would work because the post body then is not empty.
« Reply #11 on: May 16, 2016, 22:42:15 »
Welkom, Edwin. No need for words, pictures are enough
chris dees
  • Amsterdam
« Reply #12 on: May 16, 2016, 23:41:25 »
Welcome Edwin, another Dutchman to this forum. :)
Chris Dees
Edgy01
« Reply #13 on: May 17, 2016, 07:19:26 »
Welcome Edwin.
I, too, am new to this forum and site.  I also look to Bjørn's lens reviews to decide which to avoid and which to get.  For awhile I thought we lost Bjørn to Lyme Desease but apparently he is alive and well and residing within this forum a lot of the time.
I figure that (as you) that any forum with such active members has got to be a good place!
Dan
Santa Barbara, Calif
Laagwater
« Reply #14 on: May 17, 2016, 08:15:18 »
Thank you all for your nice and warm words.
I'll send you all a flower from Holland...
Regards Edwin
