Author Topic: Passage of Mercury in front of the Sun May 09, 2016  (Read 21002 times)
« on: April 25, 2016, 09:19:48 »
This is a little heads-up that planet Mercury will pass in front of the Sun May 9. It will be be visible though its full phase in Western and Northern Europe plus Eastern parts of the American continent, and through its last phase in Western parts of  the American continent including Alaska. While not as spectacular and rare as the passage of Venus in front of the Sun, it should be well worth capturing. It also looks like timing coincides with the Scotland event, so there might be another task for the gathering. What I experienced before the Venus passage was that solar filters were sold out everywhere (a colleague saved me by sharing his filter with me), so if you need to get one, hurry!
Earlier this spring I made myself a solar filter based on the Baader Astrosolar film, visual ND 5, which is safe for direct observations. I considered ND 3.8 which is listed for photographic purposes, but after looking up tables for exposure, I decided that exposures would be on the short side unless combined with other filters. Also, ND 3.8 is much harder to come by in smaller sizes; the 4x4" piece of ND 5 only cost me $15 shipped from Agena Astroproducts.
The standard recipe for making a solar filter is based on sandwiching the film between two poster boards using sticky tape. I have seen reports from some who simply have pressed the film between a couple of filters/stepup rings for a more compact solution, however that violates the recommendations to mount the film without any stretch of the film.  Here is what I did to avoid that:
I had an old 77mm filter ring from an NC filter that broke. To reduce thickness (to fit in a standard Nikon filter case) i filed down the male threads to get a flat surface (a cheap 72-77 mm stepup ring could be used instead of this). Now I applied the principle most recommended: A piece of Kim-wipe was taped down to be completely flat, the Baader film placed loosely on top of that, Locktite marine epoxy was applied to the flat surface of the filter ring, and now comes the "tricky" part: Center the filter ring at low height above the film, and drop it straight down onto the Baader film. From now on do not touch it until the epoxy is completely set overnight; it is best to do this before turning in to avoid the temptation to adjust anything...
Next day I trimmed the film to leave a small edge of a few of mm, then applied a small amount of epoxy to the inside of a cheap 77-82 mm step-up ring and pressed the filter ring with the film into it. As the film already is firmly attached to the filter ring there is no risk of getting it stretched. I applied a moderate weight on top of the filter ring until the epoxy had set.
Now I have a solar filter that fits nicely in a standard Nikon filter case and can be carried everywhere without need for carrying a larger filter in a "pizza box". (I had to trim down the ridge inside the case a little to get to the right thickness when resting in the case.)
Here the filter is safely mounted on my 300mm PF, well protected by the shade. The only disadvantage of this approach is that if used during a total solar eclipse it will be a bit slower to mount/dismount during the dark phase than one fitted on the front of the shade, but there is no need to screw it in too tightly.
To the testing - the Baader film gives a pretty neutral color opposed to the typical glass filters on the market. Here is the huge sunspot from last week which completely dwarfs Mercury and some other planets, in size.
From the solar eclipse earlier this spring, here natural sunset colors are showing with daylight white balance.
From two of the  remaining corners I made a pair of solar filters for my 8x20 Zeiss binoculars using the same principle.
Some links:
http://eclipsewise.com/oh/tm2016.html
https://en.wikipedia.org/wiki/Transit_of_Mercury
http://eclipse.gsfc.nasa.gov/transit/catalog/MercuryCatalog.html
An additional note: I had applied some double sided tape to the outside of the filter ring to attach the edge of the film to the filter ring before gluing it to the step-up ring, but this did not work very well and is best omitted unless one can find a better double sided tape than I had available.
Re: Passage of Mercury in front of the Sun May 09, 2016
« Reply #1 on: April 25, 2016, 09:38:36 »
Very nice project ;) Thanks for posting!
« Reply #2 on: April 25, 2016, 10:10:59 »
I can hardly wait to see the results!
« Reply #3 on: April 25, 2016, 10:11:26 »
Most helpful. Thank you very much!!!
« Reply #4 on: April 25, 2016, 10:57:02 »
Thanks for the comments, glad if it can be of help.
Those lucky with capturing this event, please contribute with results here if desired.
« Reply #5 on: April 25, 2016, 11:27:07 »
Great project!
Unfortunately, this Transit of Mercury cannot be observed in Japan.  I just wish you Western folks the best of luck and share the result here in NG!
« Reply #6 on: April 30, 2016, 10:54:11 »
Just a link with a reminder that Mercury will be a very small dot compared to Venus, so a lens setup with an adequately narrow angle of view is called for. This dpreview post has an image from a previous transit.
http://www.dpreview.com/forums/post/57488974
« Reply #7 on: April 30, 2016, 11:00:47 »
I plan to use 200/2 AFS + TC-14E + TC-201 = 560 mm physical, on the AW1.
« Reply #8 on: April 30, 2016, 11:21:50 »
Bjørn, I will be closely looking by with my AW1 and 300/2.8 AF-I.
I will need to borrow apart from the knowledge, the FT1 and the two TCs.
We will be taking turns on the FSB8 fluid head I suppose...
« Reply #9 on: April 30, 2016, 11:57:19 »
No need to hurry, the Transit takes hours to complete. The visibility of the Sun tends to be the major concern for these events, not time constraints.
If the weather is conducive, we might join the queue for the steam train going over the Glenfinnan aquaduct. A steam locomotive billowing smoke and the solar disk with the tiny Mercury visible through the fumes, now that would be something special. No idea whether such ideas are feasible to achieve though.
« Reply #10 on: April 30, 2016, 12:19:26 »
Jakov, David has Ais 400/5.6 ED IF which will be more handy for the TOM, with or without TC.
« Reply #11 on: April 30, 2016, 12:45:55 »
We won't impose on David's opportunities for shooting the transit himself.
as Mercury is so much smaller than Venus, one either needs a very long focal length, or the narrow range of view provided by a CX-format camera or suchlike. In the latter case, a long lens is still required and the camera resolution should be good as well.
These events are more remembered for their unique opportunity of perceiving Cosmic Scale than for the recorded details, if any, of the planet in question. Venus is almost the size of Earth thus a Venus Transit is easier to relate to in that perspective. However, there will be no more Venus Transits this century, thus Mercury has to suffice.
« Reply #12 on: April 30, 2016, 13:02:12 »
Of course, I didn't mean to take his chance away.  Only if he is not trying to capture the TOM himself.
simato73
« Reply #13 on: May 02, 2016, 10:07:42 »
I am considering buying an adapter like the FT-1 to use on the Nikon 1 system (I have an AW1) for the Mercury transit.
The lens I am planning to use is a Mamyia 500mm so no electronics whatsoever and I nave no AF(S) Nikkors so not keen to buy an expensive FT-1 if a much cheaper alternative can do the job in the same way.
What problems am I going to face using a completely manual lens with no electronics on a Nikon 1?
Simone Tomasi
Olivier
  • Olivier Anthony
« Reply #14 on: May 02, 2016, 10:43:39 »
Simone, the major issue I am facing with my cheap adapter (on a V1) is the difficulty to MF. There is no aid whatsoever.
It could be fairly easy for the transit of Mercury though as you will look for focus at infinity, with plenty of time to adjust.
