Author Topic: !DAILY UPDATES! February. 366 days: your 2016 in photographs  (Read 55853 times)
Re: Re: !DAILY UPDATES! 365 days: your 2016 in photographs
« Reply #255 on: February 22, 2016, 11:53:52 »
How it works is pretty good described here: Close Up Lens vs Macro Extension Tubes
In the field I usually don't switch lenses, but getting closer with a close up lens is very convenient.
Loss of light is minimized and all camera-controls work. For lenses you are dependent on the filter-size but step down-and up rings are a perfect tool to get them on every lens. It takes however some fine-tuning and testing which combination works best.
For the available Nikon Close-up Attachments see:  http://www.mir.com.my/rb/photography/hardwares/classics/nikonf2/macro/index3a.htm
« Reply #256 on: February 22, 2016, 11:59:43 »
John: I have some close up lenses (one 77mm Canon, some Hoya for other lenses) but they distorted the images so much that I gave up using them. Good to know it is worth to experiment more
« Reply #257 on: February 22, 2016, 12:06:57 »
Yes, there is a lot of bad-quality stuff on the market.  This is important:  "Numbers 3T, 4T, 5T and 6T are two-element achromatic lenses that still maintain a high image quality. 3T and 4T work best with lenses from 85mm to 200mm, and 5T and 6T with lenses from 70mm to 210mm."  I also use them for wide-angle lenses by the way were the effect may be less, but still is there, especially when looking for the best background.
Disadvantage is that the usage of close-up filters are not in the EXIF, unless you store it in the 'comments field' or author.
« Reply #258 on: February 22, 2016, 12:23:47 »
feb 22 2016
the sky holds a promise
D800 14-24/2.8
« Reply #259 on: February 22, 2016, 13:10:39 »
February 22nd
A miserable rainy day
Df - 85K
« Reply #260 on: February 22, 2016, 13:19:12 »
February 22nd
Df - 85K
Pavement on the Ceiling? Unusual architectural feature.
« Reply #261 on: February 22, 2016, 13:20:01 »
I used a staircase today:
Jacques
« Reply #262 on: February 22, 2016, 20:44:33 »
A man and his ladders
A.Jacks
« Reply #263 on: February 22, 2016, 20:48:19 »
Bruno. Love the birds in #701 .... D70? Really?
« Reply #264 on: February 22, 2016, 23:54:23 »
Oops no, D750. Thanks for the kind words and for pointing out. I corrected in the original post.
« Reply #265 on: February 23, 2016, 00:17:01 »
John. #720 is lovely. Such tender rendering of wet leafs
Jaques. #727. Love it. Such beautiful clarity in color and wood structure!
« Reply #266 on: February 23, 2016, 00:37:46 »
  I agree ;)
Sinking daffodils ... that's raining. Nice shots with the 4T, John. Did you also test the reverse mounting?
Quick shot under a pouring rain. Daffodils seem to resist better here :). D750 AFS 105/2.8
« Reply #267 on: February 23, 2016, 00:49:16 »
Thanks Frank  and Bruno.
The reversal of the T4 you mean? Not yet because You probably would need a 'reversal-ring' or something?
« Reply #268 on: February 23, 2016, 00:58:11 »
Yes, indeed. BjørnR. sometimes refers to reverse mounting giving better image quality with certain lenses.
« Reply #269 on: February 23, 2016, 19:13:51 »
feb 23 2016
local flooding lots of rain
Df 58/1.4g
