Author Topic: First D5 shots.  (Read 4118 times)
First D5 shots.
« on: March 27, 2016, 12:06:47 »
Nikon NIKON D5,Nikkor AF-S 600mm f/4G ED VR
1/1600s f/8.0 at 1000.0mm iso800
1/1600s f/8.0 at 1000.0mm iso320
Re: First D5 shots.
« Reply #1 on: March 27, 2016, 12:07:55 »
So whats the verdict
cool shot btw
Re: First D5 shots.
« Reply #2 on: March 27, 2016, 12:21:22 »
i need more time..... my first point of contention is moving the mode button which i use often to switch between A-priority and Manual when in Auto-ISO to the left side of the camera away from the shutter actuator and replacing it with the ISO selector which i use much less frequently..
shutter seems much quieter than the D4s... higher frame rate is nice but i didn't have a chance to exploit that yesterday.
i most shoot nine-point center which is now 21-point center which could be an improvement will have to wait to see for sure
i had some trouble with the exposure (had to keep increasing the compensation) when checking the histogram.
i tried the built in focus tuning which i couldn't find in the manual
which i found here.. and trying this out today proved a complete failure... actually tuned in the wrong direction!! so be careful. i am sure i am doing something wrong here
http://www.dslrbodies.com/cameras/the-d5d500-blog.html
Select maximum aperture on your lens (e.g. Aperture priority, wide open).
Select Still Live View (press the button to activate, with icon on still camera).
Select Single Servo autofocus (AF S).
Set the Live View AF-Area mode to Normal-area (Normal).
Select the center focus point.
Focus the camera as you normally would in Live View on your target. Update: it appears that Nikon is finessing the 80-400mm issue I mentioned. Their response is to just focus manually in live view to get the right focus point, then continue with the following steps.
Press and hold (for two seconds) the AF Mode button (front of camera) and red Video record button simultaneously.
Follow the instructions that are displayed.
Re: First D5 shots.
« Reply #3 on: March 27, 2016, 12:53:29 »
That first shot is outstanding! Wow congratulation ;)
Re: First D5 shots.
« Reply #4 on: March 27, 2016, 19:15:37 »
by the way.. auto focus tune - there may be a Nikon supplied target for tuning for it to work the right way... seems to be an undocumented feature..
Olivier
  • Olivier Anthony
Re: First D5 shots.
« Reply #5 on: March 27, 2016, 19:25:32 »
Yes, the "give me four" shot is great indeed, but not only because of the technical aspects!
Re: First D5 shots.
« Reply #6 on: March 27, 2016, 19:27:57 »
Didn't you get more nice shots today?
Weather was cold and rainy here - winter is just about here
Re: First D5 shots.
« Reply #7 on: March 27, 2016, 19:45:10 »
not a good day here when i was out.. .very overcast and dark this morning
Vilhelm
  • Mr.
  • Gone fishing
Re: First D5 shots.
« Reply #8 on: March 27, 2016, 20:16:49 »
I suggest you program the red record button to do MODE in Photo, menu f1 will give you access to reprogramming buttons on the D5
Life isn't about finding yourself. Life is about creating yourself.
- George Bernard Shaw
Re: First D5 shots.
« Reply #9 on: March 27, 2016, 23:03:00 »
good idea.. thx!
Re: First D5 shots.
« Reply #10 on: April 02, 2016, 10:17:08 »
Waw ! Perfect shots !
