Author Topic: Nikkor 135 AF DC f/2 D  (Read 87251 times)
Re: Nikkor 135 AF DC f/2 D
« Reply #105 on: June 14, 2016, 10:36:43 »
Bjørn or Erik,
Have you heard of any info on the improvement of the material of A-M ring?
Sorry I forgot to reply on this one ;)
I have never had any issues with the A-M Ring on any of my lenses, and I still have the 20-35mm 2.8 AF-D and 14mm 2.8 AF-D both working perfectly,,,
Bjørn and many others reporting on cracks and breaking,,, I have only seen this in photos online,,, not on new or used lenses.
I believe there must have been a silent upgrade in material specifications for these rings, they appear to look different, the surface texture changed at some point. But this is just a guess - I believe it can bee seen/deducted from Rolands pages last time I had a look,,,
« Reply #106 on: June 14, 2016, 11:57:08 »
I agree with with Erik on every count.
My 85/1.4 D is 12 years old and I haven't encountered difficulties with the A-M ring.
Also, Roland needs to update the serial numbers since my 135 DC goes beyond his listing of 520919, and it's 521117 :)
« Reply #107 on: June 14, 2016, 12:07:01 »
Erik and Jakov, thanks for sharing your experiences with the A-M rings.  Personally I think I have seen a sample with a cracked ring at a named camera store in Tokyo.
On Roland's website, 135 and 105DCs are the only lenses for which the images of two different samples can be seen.  I cannot detect any differrences.  The newer version looks a bit like CG.
Hope Nikon improved the material or construction to address the issue.
« Reply #108 on: June 14, 2016, 22:31:22 »
Thanks Jakov, I'm sure all the serial numbers need updating, Nikon keeps making more! But I can only add numbers that I know about :)
I'll add yours to my database. When did you buy it?
As for the A-M ring, maybe in the cold it becomes brittle or shrinks relative to the barrel so is put under tension and therefore cracks at the weak point near the release button. That might explain why Bjørn has problems with the A-M ring in the Nordic cold, while others in warmer climes are unaffected ??
« Reply #109 on: June 14, 2016, 23:13:48 »
According to the 1st page of this thread I received the lens on 13th April :)
« Reply #110 on: June 17, 2016, 10:55:03 »
Just refreshed my site, your lens (or the serial number at least) is now world famous :)
« Reply #111 on: June 17, 2016, 10:58:38 »
World famous at last, thanks Roland  ;)
chambeshi
« Reply #112 on: June 25, 2016, 15:56:34 »
Thanks to all for your guidance on the intricacies of this remarkable lens. I have an early pre D model of the 135 f2 DC, and am using it on a D7200. Still much to learn.....
« Reply #113 on: June 25, 2016, 19:59:06 »
chambeshi, my name is Jakov. It would be great to know your name. We all like to know with whom we're talking to.
The second to last purple one is nice.
« Reply #114 on: June 25, 2016, 21:10:39 »
Probably of only passing interest, if that, to most. These DC lenses can be stacked with the front of the image defocused AND the rear of the image also defocused.
Then, when the two images are stacked, you get a central image in focus, with both front and rear of the image defocused, as opposed to a linear grading in one direction, as most images demonstrate.
Shot with the Nikon D810 and the 135mm AF DC at f/2, both defocused and pushed as far as possible. You can clearly see this in the photo of the larger (taller) flower that the focus (such as it is) in the lower part of the front center of the flower, and there are defocused areas both in front and behind. Might be useful; might not.
« Reply #115 on: June 26, 2016, 09:05:39 »
Seems like a new concept to me, de-focus stacking  :D :D
« Reply #116 on: June 26, 2016, 18:24:57 »
Micheal I like the concept. Show us some more where the DC is more pronounced, please :)
chambeshi
« Reply #117 on: July 19, 2016, 12:14:26 »
two recent photos with the 135 f2 DC on moving subjects, a Chinese goose and flock of Indian Runner Ducks
chambeshi
« Reply #118 on: July 19, 2016, 12:23:26 »
One more portrait ISO 200, f6.3 on D7200
« Reply #119 on: October 27, 2016, 21:49:36 »
Chambeshi, these are nice portraits :)
