Author Topic: Nikkor 6mm 2.8 Ai  (Read 103312 times)
RonVol
Re: Nikkor 6mm 2.8 Ai
« Reply #210 on: July 02, 2016, 00:54:19 »
This has been a great thread to follow, especially the images Erik has been uploading to flickr.
Thanks heaps for sharing the impressive results.
I'm wondering how the lens/relay system ended up performing for the video test?
Are there any examples that we can view?
« Reply #211 on: July 02, 2016, 10:07:05 »
Thanks ;) I had great fun shooting that big lens
Here is an still image with the relay
_EGL2384 by Erik Gunst Lund, on Flickr
Quite impressive performance I think
RonVol
« Reply #212 on: July 02, 2016, 12:13:35 »
Here is an still image with the relay.
Thanks Erik.
I'd missed that one on your flickr page.
Yes I agree, quite impressive............considering all the glass that the light has had to travel through, the image has remained quite sharp.
Please let us know when you upload any video footage.
« Reply #213 on: July 02, 2016, 13:17:21 »
The video was posted in the Scotland thread ;)
Here the video. Butt of Lewis - Nikkor Fisheye 6mm Nikon D810 16:9 Video - Lens relay 35mm 1.4 50mm 1.2 Ais
http://nikongear.net/revival/index.php/topic,3494.msg51627.html#msg51627
https://www.youtube.com/embed/ZLxgon9x9_Y
The end framing is directly into the sunset, giving an unique orange circular flare along the edge of the frame ;)
« Reply #214 on: July 02, 2016, 13:27:47 »
Here is a 100% crop from the still frame, very impressive IMHO
BTW the weather was challenging, rain and lots of wind,,,
« Reply #215 on: July 02, 2016, 14:23:09 »
A side note: I spent quite some time trying to optimise the output from the relay system by combining various optical items and spacers. The final configuration worked very well for HD video at least, producing crisp and clear footage.
Inserting a field lens into the relay might have improved rendition further because the relay optics could be stopped down more, but vignetting is always an issue in these setups. A general notice is that the only stopping down should occur at the front lens, in this case the 6 mm f/2.8 Fisheye, not on any of the relay optics. I mention this because it is a counter-intuitive principle to what most people would select, but the recommendation has a most reliable source (Brian Caldwell).
« Reply #216 on: July 02, 2016, 16:05:25 »
A huge thanks to Bjørn for assembling the relay and to Jan Ann for lending me his 50mm
The peak image quality was at f/5.6
By a huge margin!
The whole set up of the relay was very tricky, the tolerances to reach peak performance was super tight. I used quite some time as well fine tuning the optimal length of the k-rings to enable a margin to 'focus' the length of the relay.
« Reply #217 on: July 02, 2016, 16:40:14 »
Here's Erik in action at the Butt of Lewis, always with one hand on the setup to prevent it from tipping over the cliff  :)
Canon 85/1.2 FD SSC on Sony a7S, wide open
Voigtlander 15/4.5 FE on Sony a7S
« Reply #218 on: July 02, 2016, 16:44:08 »
And the big fish in action at the Stones of Callanish, Isle of Lewis.
Canon 85/1.2 FD SSC on a Sony a7S
Canon 100-400 IS MkII on Sony a7RII
« Reply #219 on: July 02, 2016, 17:26:03 »
Finally got around not only to see, but actually use, this legendary lens. Still no CPU in it, though but the new owner has just to call :D
Kim Pilegaard
  • "Nikea"
« Reply #220 on: July 06, 2016, 09:32:29 »
220 degrees 360 degrees makes for a huge difference indeed,,, That's why I build the vertical base ;)
I have offered to sell the vertical base to come along with the 6mm, if he doesn't buy it I'll re-build it to fit the 10.5mm AF-D to be able to do two shot stitches of approximately 200 degrees for 360 degree circular images similar to the 6mm but filling the D810 frame quite a bit more, I have all ready started the thread some time ago,,,
And if he buys it I will do a similar but smaller rig, no need for the same heft since the 10.5mm is tiny!
It can actually just rest on the Zacuto finder frame and rotate on that
Erik,
Could you elaborate a little bit on how to use the 10.5mm AF-D for 360 degree circular images? (an example would be great!)
Kim
« Reply #221 on: July 06, 2016, 09:44:59 »
Kim have a look in this thread:
http://nikongear.net/revival/index.php/topic,2948.new.html#new
Best to keep it out of the 6mm thread I think ;)
Kim Pilegaard
  • "Nikea"
« Reply #222 on: July 06, 2016, 10:36:32 »
Thanks - looks very interesting!
Kim
« Reply #223 on: July 26, 2016, 17:08:05 »
Here another 'Product' from the Scotland Event and the 6mm Fisheye Nikkor - A meeting table.
I'm really impress by the carpenters work - including the tree like that.
_EGL5685 by Erik Gunst Lund, on Flickr
And here with glass top - I'm sure an anti-reflex coating would have done this justice,,, but expensive,,,
_EGL5686 by Erik Gunst Lund, on Flickr
« Reply #224 on: July 26, 2016, 17:28:54 »
Fantastic ! is only word that comes to mind.
You could have built a formidable industry out of this lens, Erik. A pity it was passed on.
