Author Topic: The Nikkor-Q 200mm f/4!  (Read 68978 times)
« on: March 08, 2016, 04:14:47 »
http://richardhaw.com/2016/03/07/repair-auto-nikkor-q-200mm-f4/
crazy, I got this lens for $3.50  :o :o :o
i was not expecting this lens to perform well since it is old and with all that fungus in the glass i was assuming that the glass was etched beyond repair. i was proven wrong!  ::)
this lens performed great on the D750's sensor. it is sharp, saturated and contrasty!
this was such a surprise because i got this lens for the purpose of salvaging this lens parts but I ended up restoring it and using it for myself...
the first version was not good according to some people but this (2nd) version sure is amazing!
Re: The Nikkor-Q 200mm f/4!
« Reply #1 on: March 08, 2016, 04:22:31 »
some people also claim that this lens performs exceptionally well with the T micro filter from Nikon  :o :o :o
a friend also told me that this is also a great lens when used as a relay lens for macro photography...
« Reply #2 on: March 08, 2016, 05:05:35 »
Good job, Rick!
My Nikkor-Q C amazes me either on FX, DX or even m4/3.  It does show some LoCA in the OOF areas which can be mitigated in CC2015 fairly easily.
I have Kenko No.2, 3 and 5 achromatic closeup lenses.  I will try them.
« Reply #3 on: March 08, 2016, 05:13:30 »
Good job, Rick!
Thanks! i wonder how this thing performs with TC  :o :o :o
charlie
« Reply #4 on: March 08, 2016, 05:35:50 »
And I thought I got mine for a steal for $40 in like new condition.
« Reply #5 on: March 08, 2016, 06:44:04 »
it usually costs around that. mine was heavily infested with fungi, even the metal parts had them  :o :o :o so they sold it for $3.50
« Reply #6 on: March 08, 2016, 08:59:30 »
Good job, Rick!
That C-version is the first multi-coated one, not?
These first multi-coated versions perform very good.  I noticed that on the 135/2.8 Q C as well.  They also give probably a half stop more light than the 2.8.  Close up lens works perfect there too.
The same applies for the 85K /1.8  the first multicoated version. It's very close to the later introduced 85/1.4 (apart from the design, obviously).
« Reply #7 on: March 08, 2016, 15:18:37 »
John, I believe the Q C 200mm/f4.0 was one of the first Nikkors to be multi-coated (in 1973?).
I also wanted 85/1.8, but its 6-blade straight aperture made me back off...
« Reply #8 on: March 08, 2016, 15:26:09 »
this lens should look great with the Df.  :o :o :o
anybody knows how ugly the original version is compared to this or the C?
« Reply #9 on: March 08, 2016, 15:29:53 »
Rick, I don't necessarily think that the original version was all that ugly.  But the narrow grip of its focus ring appears to be awkward to operate.
« Reply #10 on: March 08, 2016, 15:32:27 »
More like it produced a strange impression by the combination of metal and paint plus the stair-case like stages in its outline. I get the same feeling when I look at the first zoom Nikkors of the '60s too. The mechanical side of the affair probably came last in the development of the lens.
« Reply #11 on: March 08, 2016, 21:10:20 »
1973 for 85, 105, 135 and 200, but 1972 for the 50mm's  according to Roland Vink's database. It depends which multi-coating is meant, I am not sure?
What are your objections against a 6-blade straight aperture?  The bokeh of the 85/1.8 K  can be as smooth as any 1.4 lens ;)
« Reply #12 on: March 08, 2016, 23:59:33 »
The transition from older single-coated to multi-coated lenses in the early 1970s is quite clear. Back then there weren't different types of multi-coating.
Originally it was known as multi-layer coating, later Intergrated Coating (IC) and then Nikon Integrated Coating (NIC). All are essentially the same thing, although there a likely to be improvements along the way. The first "new" coating was Super Integrated Coating (SIC) which started appearing around 2000? This is supposed to be more effective over a wider range of wavelengths, but is not a radical change. The last real improvement is Nano-Crystal-Coat which works in a different way and is much more effective, but is also expensive and delicate so is only used on selected internal surfaces, the rest are still SIC.
« Reply #13 on: March 09, 2016, 01:49:26 »
If I'm not mistaken, there have been no Nikkor lenses that uses Nano Crystal Coat on more than one lens surfaces.  So its use is very limited.
null
« Reply #14 on: March 09, 2016, 02:05:03 »
The Nikon/Nikkormat Handbook, Joseph Cooper, states that the selected groups of the Nikkor-S 55/1.2 were the first to be multicoated, starting in 1969. The selection of surfaces being multi-coated were "guided" by the computer. I believe the 35/1.4 and 28/2 were multi-coated early on. I had one of those 55/1.2 lenses, but sold it and kept the Nikkor-SC.
