Author Topic: New Tamron lenses - 85/1.8VC and 90/2.8VC Macro  (Read 11531 times)
KarlMera
Re: New Tamron lenses - 85/1.8VC and 90/2.8VC Macro
« Reply #15 on: February 23, 2016, 15:45:48 »
these zeiss lenses i mention have no cpu contacts, so my only guess now is that register distances are not accurate,( which is more sensitive at larger apertures).
I have many old lenses for Nikon without cpu, but the dot works, D800.
« Reply #16 on: February 23, 2016, 16:00:14 »
Right, i dont have such issues with the many old nikkors i use, but with the zf 35/2 and 85/1.4, maybe with 100/2 i am not sure about the last , well its a macrolens anyway so i use  lv here, thank you Karl.
« Reply #17 on: February 23, 2016, 18:13:38 »
The green dot may behave differently with different lenses. Due to some unknown-to-me optical principles, my ZF 85/1.4 and ZF.2 25/2(both now gone) seemed more difficult to eye focus than other ZF lenses.
KarlMera
« Reply #18 on: February 23, 2016, 19:34:27 »
But it also works with old manuel Vivitars and Sigmas, why does it not work with Zeiss?
« Reply #19 on: February 24, 2016, 09:40:31 »
to narrow it down my copy zf35mm f/2 is the real bitch, i simply can not focus at f2
« Reply #20 on: February 24, 2016, 15:17:18 »
On all Nikon bodies?  My experience with D700 and Zf35/2 is a bit the same, on the Df and 800E it all goes smoother. I hardly use the green dot by the way, focus-screen only. Only in dark situations it is inevitable.
« Reply #21 on: February 24, 2016, 19:17:44 »
With my D3, the ZF 35/2 was relatively easy to eye focus.  It is only slightly more difficult with the D800/E, but only because my D800 finder is optically inferior to my D3 finder.
« Reply #22 on: February 24, 2016, 19:40:57 »
first my eyesight is not optimal, second distance to focuspoint is important, third which focus crosspoint is selected, when ambient light distorts contrasts,
on the d800 i have 1,2X magnifying eyepiece with helps and liveview is no problem
« Reply #23 on: February 26, 2016, 09:51:39 »
DPR is reporting that the 85mm in F mount has an electronic aperature, they don't mention anything about it on the 90mm
« Reply #24 on: February 26, 2016, 12:07:47 »
http://richardhaw.com/2016/02/26/cp-2016-pt-2/
check my samples of the tamrons!!!  :o :o :o
damn this is an awesome lens!
« Reply #25 on: April 12, 2016, 14:20:10 »
For me a drawback to most non-Nikkor lenses is they frequently focus the reverse direction to Nikkor lenses. This messes with my reflexes when I use manual focus.
Years ago I bought a 400/6.3 Tele-Astronar preset lens. Later when I bought an 80-200/4.5 Nikkor I found I focused the correct direction at the close end of the zoom but backwards at the long end. The fingers had learned that long lenses focus the reverse direction to other lenses. I parted ways with the 400/6.3.
A switch to a different camera system isn't much of a problem. It's when lenses for one system focus reverse to each other.
« Reply #26 on: April 12, 2016, 22:21:35 »
the 85mm f/1.8VC looks exciting as well. I tried their 35mm and 45mm and they were both AWESOME lenses for their price. the build quality is also great
Indeed. The 45/1.8 is not only good, it is also a "lens with a personality", and its "signature" is very different from Zeiss. This is all good news.
