Author Topic: IR Conversion bodies (which one?)  (Read 33667 times)
Re: IR Conversion bodies (which one?)
« Reply #90 on: November 17, 2016, 11:18:16 »
i don't know about cameras or anything super complicated, but in automotive if something is heating up like that then the wiring has a problem. probably a short or ground was not setup properly, old wires, happens sometimes on the ignition part of some older toyotas and drain your batteries :o :o :o
might be useless information but the camera might be trying to say something.
the only thing that I am aware of that actually heats the camera is long exposure and liveview/video.
Bern
« Reply #91 on: November 17, 2016, 12:16:54 »
My initial thoughts also that it maybe the wires. does the sensor warm up because of the IR filter attached?  It has not come to the point where it becomes uncomfortable to use. But i will be observing it as I use it.
Does having converted the body use up more battery than a standard body?
Keep shooting,
Bern
« Reply #92 on: November 17, 2016, 12:34:12 »
To the last question the answer is a resounding 'NO'.
stenrasmussen
« Reply #93 on: November 17, 2016, 12:47:41 »
I don't believe the conversion itself causes the heating. The capacitor could be a heat source but would not heat up unless it's about to fail. Does a different battery help?
JJChan
  • JJ Chan
« Reply #94 on: November 17, 2016, 14:30:44 »
FWIW, I have (self) converted D200 and this does not heat up at all.
It does chew through batteries compared to more modern DSLRs with same battery (e.g. D300, D700) but no more than my other unconverted D200s.
JJ
Bern
« Reply #95 on: November 18, 2016, 01:35:20 »
Appreciate all your answers! I may just have to observe it for a while. I had it converted as soon as I got it from an online seller, used but still in good condition. The shutter count was (only) around 39K which I thought still have a lot of life left in it. Converting it to IR would give it a new lease on life. Will try to post some samples soon.
Thanks!
Keep shooting,
Bern
