"NG 10 Years" competition: RESULTS !!!https://nikongear.net/revival/index.php?topic=11252.0Current status: 86/150 supporters
PN11
Well,,, the hardware is build into a PB4 or PB6,,, not really easy to use on another device
I would guess you could turn the adapter between 0 deg and 90 deg,,,Take a couple of close ups of the F mount adapter and bellows mount
That is the problem of the Rollei, you can not rotate the 810, with pn-11 you can not tilt because of vignetting. With the Horseman vcc pro you can rotate 360°.
Very good, I have the same one on my novoflex bellows, but I can rotate 360°.
Actually there is a very easy solution to this. The Novoflex PROLEI Bellows Adapter (Leica M39 thread) is a wide circular piece, in which an M39-Nikon/F-Mount adapter is mounted. This PROLEI adapter can simply be rotated 90-degrees and locked into place and there you have it. It is an operation that takes all of two seconds to rotate from horizontal to vertical or vice versa.Problem solved.
Quite difficult to see without any images,,,
