Author Topic: Nikkor 35/1.4 AiS  (Read 2831 times)
Andrew
Nikkor 35/1.4 AiS
« on: February 03, 2016, 17:01:39 »
Anybody has repair manual for this lens??
Could I use it?
Thanx
And
Andrew Iwanowski
stenrasmussen
Re: Nikkor 35/1.4 AiS
« Reply #1 on: February 03, 2016, 17:55:21 »
There are really no service/repair manuals for these Nikkors. Some exploded parts diagrams exist. May I ask what the problem is?
Andrew
« Reply #2 on: February 03, 2016, 18:01:22 »
Yes Sten!
We cannot put it together, I did find some info on the Net-but only about version Ai, looks like Ai-S is different.
Any idea what to do??
Andrew Iwanowski
stenrasmussen
« Reply #3 on: February 03, 2016, 18:22:13 »
Yes Sten!
Has it been totally disassembled or..?
« Reply #4 on: February 03, 2016, 18:29:01 »
Several things has to come together at the same time;
Aperture leaver follower must be able to catch the stop down leaver. The mechanism that stops the lens down. Small leaver
Aperture setting on lens must catch aperture ring setting. The mechanism that determine how far down the aperture will stop down. A little u-shaped sliding thing must be at f/5:6 (you must guess)!!!  and then set aperture ring at f/5.6
The tap of the CRC element must catch the guide inside the helicoil assembly
Then the top indication screw must slide into the top notch of the helicoil assembly
charlie
« Reply #5 on: February 03, 2016, 23:29:24 »
Andrew, for curiosities sake would you mind sharing pictures of this lens apart?
Andrew
« Reply #6 on: February 04, 2016, 09:22:02 »
Thank Eric!
I think you hit the nail strait,,,, Thank you!
Pix: we will do!
Andrew Iwanowski
« Reply #7 on: February 04, 2016, 11:29:07 »
Erik. I bet you can asspemble this lens in the dark with closed eyes after 10 cans of beer. Great "head cinema" description.
