Author Topic: The Voigtländer 180mm f/4 APO-Lanthar  (Read 4731 times)
« on: January 27, 2016, 19:13:39 »
In these last days I have been looking at the various Voigtländer lenses. One of the Voigtländers that fewer lenses that folks seem to collect is the Voigtländer 180mm f/4 APO-Lanthar. This is a very sharp and well corrected lens, although the minimum focus distance is a little long for the work I do. It is not a close up lens, but it does take extension pretty well.
Here is a photo taken with the Nikon D810 and the Voigtländer 180mm, with a little extension (K-1 ring), stacked with Zerene Stacker. What I like about this longer lens is that the subject is more in the same focus distance in the photo so that there are less artifacts to deal with in post processing.
Dane
Re: The Voigtländer 180mm f/4 APO-Lanthar
« Reply #1 on: January 02, 2018, 11:55:51 »
That's one of my most favorite lenses of all times. I really love the way this lens draws when taken pictures in the close focus range.
It's really 3Dimensional. The lack of chromatic aberrations, its small size and perfect optical quality make it a total package for me.
« Reply #2 on: January 08, 2018, 00:32:46 »
Wonderful lens, had it, but sold it due to not enough use...
longzoom
« Reply #3 on: March 15, 2018, 05:25:55 »
In my own experience with this lens, it is not tolerate well any, even smallest, extensions. Much better results I got with using APO-chromatic screw-ups. Would you, Michael, give it a try?  LZ
« Reply #4 on: March 15, 2018, 08:14:09 »
I don't like extensions and the CV-180 doesn't like them either. Of course, some folks will use and love them. The K1 ring (5.8mm) will work on some lenses and about all I ever try to use on any lens. Again, horses for courses.
« Reply #5 on: February 03, 2021, 23:31:55 »
Just got mine by Fedex from Japan. Near mint, optics are absolutely clean and focus action is ideal - fluid, neither too loose nor too stiff. The lens is as good as aberration-free, reminding me of the Zeiss 135/2. I'll take it out as soon as the rain stops and when I get the step-up ring to put a lens hood on (HS-4, HN-7, or similar).
Here two shots of young Jesus and parents, a terracotta by Rosa Ramalho (see https://en.wikipedia.org/wiki/Rosa_Ramalho ; I met her when I was a youngster...).
First one is cropped, f/4, handheld, ISO 3600. Second one at f/22, ISO 100, uncropped and on a tripod. I have no reason to complain. Diffraction ? not really noticeable. LoCA ? none. Color ? nice (as much as bulbs can make it possible).
I only saw one strange phenomenon on stopping down between f/4 and f/22, namely slight color shifts (towards green) on certain stops. That's probably related to varying stray light reflections, only noticeable in LiveView, and anyway minimal.
Thanks to several NG members for advice, and especially for "tipping the scale" towards buying. Despite the price tag (aggravated by import tax), it is worth every penny. The relatively light weight and incredibly small size make it an ideal travel companion for my old Df and my old back. It does not compromise at all on optical quality (unlike the otherwise remarkable Elmar-R; comparisons to follow in another thread).
Now the question is, when shall we travel again...
« Reply #6 on: February 04, 2021, 07:22:08 »
Congratulations Airy !
Indeed the 49mm is an odd filter-size. The setup ring 49-52mm is attached on my lens for a sun hood.
« Reply #7 on: February 04, 2021, 07:31:13 »
ggoodes
« Reply #8 on: February 09, 2026, 18:12:51 »
Pro tip: Nikon's HN-30 lens hood (designed for the Micro-Nikkor 200/4 AF-D) is a GREAT solution for the 180/4 APO-Lanthar.  It is a high quality metal hood, with crinkle-paint exterior and matt-black ridges inside.  It is quite a bit longer than the other Nikon hoods mentioned above, which hopefully addresses the flare problems the 180/4 seems to exhibit.  The HN-30 will require a 49mm to 62mm step-up ring to mount it.  It's a bit of a rare hood, but I managed to find an old-stock in-box copy for a great price.
Gerhard2006
« Reply #9 on: April 08, 2026, 19:10:52 »
I noticed here that this 180 mm lens does not handle extension well. I have the 180 mm 2.8 AFD Nikkor lens. Birna said years ago it handled extension tubes really well. It may not be totally Apochromatic but that one ED glass of element seems to handle chromatic aberration pretty well. I know I’ve used it with a 6T close-up lens and that works very well, but I’ve never tried it with extension tubes. I will have to try it when I get home. I will keep you posted. Regards, Gerry.
ggoodes
« Reply #10 on: April 08, 2026, 21:45:23 »
Interesting: Since the Voigtländer 180/4 doesn't seem to have any CRC, and just has a _really_ long helicoid, I'm surprised it would care about extension tubes: 1:4 (closest focus) should be much the same as 1:2 (with a PN-11 or whatever).  Will have to try mine out with the PN-11 and see.
