Author Topic: [Theme] The Number 13  (Read 228426 times)
Re: [Theme] The Number 13
« Reply #720 on: September 04, 2022, 00:32:27 »
Dolmen 13? Oleeee
Today I'm at a flamenco festival in Vejer de la Frontera. Best seat in the audience.
Huawei p30 lite
mxbianco
« Reply #721 on: September 10, 2022, 17:30:27 »
Chairlift, seat #113
Zfc, 16-50mm
Ciao from Massimo
« Reply #722 on: September 10, 2022, 20:16:43 »
Great reflexes Massimo. Thanks for such interesting addition!
  • Fairbanks, Alaska
« Reply #723 on: September 11, 2022, 07:41:06 »
I was assigned room #13 at the lodge we were staying at.
A forewarning of what was to come a few days later?
(Which also formed the combination of the number 1 followed by 3 of the same kind ...  - stuck at a hotel in Anchorage)
mxbianco
« Reply #724 on: September 11, 2022, 08:37:22 »
Thanks, Paco! The chairlift was actually moving quickly, they were doing maintenance for the winter skiing season...
Here's a more static one...
All paths eventually lead to Rome, but...
...most paths are numbered 13 !
Ciao from massimo
  • Fairbanks, Alaska
« Reply #725 on: September 12, 2022, 06:17:27 »
Ciao from massimo
Nice one - the #13 path can lead many places as seen in this thread.
« Reply #726 on: September 12, 2022, 09:02:00 »
Øivind,first and foremost, I hope you are all doing well. Take care
  13 is probably doing some extra layer of protection at this point  ;)
  Massimo, ancora, 13 marks the distance. Great finds!
mxbianco
« Reply #727 on: September 12, 2022, 09:41:54 »
Øivind,
From me too, all the best to you, now that you can laugh about it, probably means healing is on the way...
This one has some relation to Covid:
Morbo-13
Nikon Z fc, NIKKOR Z DX 50-250mm f/4.5-6.3 VR
Ciao from Massimo
  • Fairbanks, Alaska
« Reply #728 on: September 12, 2022, 10:10:43 »
Thanks for your concern Paco and Massimo. After the negative test the first positive was a bit shocking as it was dark blue the moment the fluid hit the T-line! This was in mid-August and I escaped from isolation after the recommended 10 days (as when still tesing positive at day 5, that was #3 from top).   I have later tested negative a couple of times around the 2 week mark, so that was about how long it took. It was what in media is being called a mild case. That brings the expectations that it is something like a very mild cold, perhaps hardly noticeable, but it was nothing that felt mild about it. Digging into that CDC definition, it means one are just not gasping for air, opposed to what is called moderate COVID-19! So try to stay off even mild cases.  :o  (Massimo, I se a proper NO the the right in your image.) But at least I got 5 cases of #13 in one frame (counting the drop symbols as ones  ;D  )
« Reply #729 on: September 17, 2022, 14:23:39 »
Twice as nice
« Reply #730 on: September 17, 2022, 17:02:15 »
Twice as strong  :)
« Reply #731 on: September 17, 2022, 17:58:25 »
« Reply #732 on: September 18, 2022, 14:33:49 »
Twice as nice
Doubling up, not bad that one  :D
Brute
  • Podunk USA
« Reply #733 on: September 19, 2022, 17:23:15 »
Ken Smith
« Reply #734 on: September 26, 2022, 19:03:14 »
13 in pink
