39 or 40.5 mm filter threads are common, Frank. Get hold of such filter(s) and try what fits. 43 mm is also seen on older lenses.
As soon as you have found the correct size, making a reversal ring is a breeze by use of step rings or similar. If the intended host lens is say 52 mm, you add a 52/52 "macro coupler"to the stack of rings.
I believe 40.5-52 direct step rings exist. Not so sure about 39mm, as it is less common. For 43 mm, 43->49 is ubiquitous and 49->52 also is standard size.
