Author Topic: Painting with Lenses  (Read 53584 times)
Re: Painting with Lenses
« Reply #120 on: January 18, 2016, 22:37:29 »
Frank, I wish the lens is of a retro focus type and the focal point is still outside the lens.  A 25mm lens put on a camera whose flange back is 46.5mm is already a significant extension.  You might have to reverse-mount the lens in order to be able to focus something in the first place.
« Reply #121 on: January 18, 2016, 23:25:39 »
Thank you Akira. I just dive into the topic. Might be some mistakes made first....
« Reply #122 on: January 22, 2016, 15:35:26 »
Tair 11-A, 135mm f/2.8 mounted on a nikon 1 V1
ArendV
    • flickr
« Reply #123 on: January 22, 2016, 15:42:50 »
Helios 40-2 (85/1.5) on A7
Arend
« Reply #124 on: January 22, 2016, 15:44:30 »
Very nice. Tells a story.
« Reply #125 on: January 22, 2016, 18:13:42 »
Gorgeous, moody, well defined, great color scape, nearly duo chrome.
« Reply #126 on: January 22, 2016, 18:33:47 »
I like the stained glass impression of the background, which appears like been seen through patterned glas.
« Reply #127 on: January 23, 2016, 05:06:41 »
Again, Nikkor-O 55/1.2, possibly at f2.0 or 2.8 on D7000.
« Reply #128 on: January 23, 2016, 05:09:38 »
AF-S 50/1.8G is not all that bad wide open...
« Reply #129 on: January 23, 2016, 10:18:07 »
The Biotar works. I just held it in front of the bayonet because I do not have the right diameter of reverse mount yet.
These are all at f=2. With proper mount and tripod I dare to close the aperture more:
« Reply #130 on: January 23, 2016, 11:26:43 »
Duh, of course with such close object distance ;-)
At 1:1 the image circle is double of the one at infinity...
« Reply #131 on: January 23, 2016, 11:28:29 »
Typical lens for "painting with light", very bubbly bokeh, even swirly BG.
« Reply #132 on: January 23, 2016, 11:32:48 »
Good for you, Frank!
By the way, the "technique" you used seems to be called "Lens Whacking".  :D
https://www.cinema5d.com/lens-whacking-how-to-create-stunning-in-camera-effects-part-1/
« Reply #133 on: January 23, 2016, 16:20:44 »
more like "freelensing" I guess  ;)
« Reply #134 on: January 24, 2016, 20:30:20 »
That would be a more elegant term.  :)
