Author Topic: [Theme] Show Birds  (Read 479628 times)
Nasos Kosmas
  • Athens, Greece
Re: [Theme] Show Birds
« Reply #1710 on: May 01, 2025, 19:23:24 »
Arturo thank you for the info :)
I post the bee eaters shot on Facebook and someone said that due to color differences the left is a female and the other is a male, you maybe right about the eye color I will try to remember .
Nasos Kosmas
  • Athens, Greece
« Reply #1711 on: May 01, 2025, 19:43:16 »
Here are two European Kestrels the one to the right with a snack. They find something to eat in the fields and then  go up to eat it.
Z8 180/600, in monochrome  and color, I noticed that 180/600 has a little more saturated colors than 500 pf 8)
This is Z8 Standard profile changed to have slight less contrast
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
« Reply #1712 on: May 04, 2025, 13:02:38 »
It's interesting because of the symmetry, good shot Nasos
« Reply #1713 on: May 04, 2025, 21:03:20 »
Very nice color shot, Nasos, +1 for the symmetry. The Kestrels seem to live a rather dangerous life if those lines are live!
Tom Hook
  • Tom
« Reply #1714 on: May 04, 2025, 23:47:14 »
Jekyll and Hyde
ARTUROARTISTA
    • APM Pintor
« Reply #1715 on: May 05, 2025, 14:50:50 »
Revolutionized planes, they didn't stop for a second
Nasos Kosmas
  • Athens, Greece
« Reply #1716 on: May 05, 2025, 16:04:18 »
Thank you Oivid, symmetry was the key for this shot
Tom very nice shot especially the second  :)
Thank you Arturo :) and yes Swallows are in my list since last year ;D
I spend a couple of hours in a small lake to be able to have a good photo of shallow  touching down the water for insects :o
It was very challenging, the Z8/180-600 was heavier than Z8/500pf used  last year and slower AF >:( so  almost impossible to use EVF
But I found a workaround: I used precapture 1 sec  with 30 FPS (jpeg >:() and trying  to guess where  the bird is without using EVF or back monitor, just pressing 3D AF button and shutter almost continuously ;D
it worked!!!
Z8 /180-600 , 460mm   f6.3 1/4000 sec Iso 2000
senecaman
« Reply #1717 on: May 05, 2025, 16:15:50 »
Nasos
An impressive selection of recent photos
Do you hand hold your lens or use a tripod & gimbal head?
Andrew
Nasos Kosmas
  • Athens, Greece
« Reply #1718 on: May 05, 2025, 16:24:54 »
Thank you Andrew!!
I had a tripod with gimbal used for some video but I find it limited for action, so I ended up  handheld
« Reply #1719 on: May 06, 2025, 09:22:09 »
Well done, Nasos.
« Reply #1720 on: May 06, 2025, 09:53:01 »
Nasos Kosmas
  • Athens, Greece
« Reply #1721 on: May 06, 2025, 23:55:04 »
Thank you  Bruno and Øivind :)
Lets go back to traditional Bird shots, here is a female Lanius collurio
Greek name is: Αετομάχος, means the bird who is fighting an eagle
ARTUROARTISTA
    • APM Pintor
« Reply #1722 on: May 07, 2025, 09:00:43 »
This subspecies of shrike is not found in Murcia, here you can see Lanius excubitor and Lanius senator.
Nasos Kosmas
  • Athens, Greece
« Reply #1723 on: May 07, 2025, 11:59:36 »
We also have these two spices here, I have seen and shot Lanius Senator several times.
ARTUROARTISTA
    • APM Pintor
« Reply #1724 on: May 09, 2025, 00:48:51 »
A kingfisher, Salinas de San Pedro, Murcia.
