Author Topic: [Theme] Show us your best moon (and solar system) images  (Read 353068 times)
« Reply #1170 on: January 05, 2025, 09:40:15 »
Thanks Colin, today might be the last clear night here for a while as clouds moved in later from the south and with Saturn also participating in the community lineup with Luna and Venus, I just could not resist another capture. This one, also with the 85mm f/1.8  was about an  hour later so the background changed to colder blue. Handheld shot at 1/8 sec was on the long side but worked for some of the tries.
« Reply #1171 on: January 05, 2025, 11:41:56 »
Nice moon.
« Reply #1172 on: January 05, 2025, 18:11:10 »
I'm often amazed at the sharpness of the starscapes my mobile phone can capture, even when handholding with nothing to steady myself against.
(i think software is doing a lot in the background as the exposures are often 5-6 seconds)
...Handheld shot at 1/8 sec was on the long side but worked for some of the tries.
But if back when the D3 came out, someone had told you that its great-granchildren would allow you to handold an 85mm lens at 1/8th, you might have been surprised :)
« Reply #1173 on: January 05, 2025, 20:31:46 »
Thanks Bruno and Colin. Yes the night mode on the phones are doing some tricks, stacking multiple aligned shorter exposures. I am often amazed how well the IBIS on the Z8 works even in sports mode which is my standard setting unless I bother to change it. My chipped 105 and 135mm AIS lenses got a new life on the Z8 in this respect, although admittedly the AF on the 85mm f/1.8S is good to have.
Nasos Kosmas
  • Athens, Greece
« Reply #1174 on: January 06, 2025, 17:50:19 »
Nice captures here  ;)
I missed the moment :(
« Reply #1175 on: January 06, 2025, 18:49:50 »
Next moment is soon, Nasos. Mars will be close to the moon during the night of January 13 to 14. It will be right above the moon's north pole at 5h TU, if I'm correct. If clouds allow, I'll be out.
« Reply #1176 on: January 07, 2025, 06:05:39 »
Stellarium is your friend. The position will vary with latitude, and timing. The date of opposition is almost the same, 15-16 January. Closest approach of Mars to earth will be 4 days earlier.
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #1177 on: January 07, 2025, 15:55:42 »
Hello Ølvind,
may I ask what kind of chips your AIS lenses are equipped with? I am asking because with my Dandelion-chipped lenses it seems that IBIS doesn't work (Nikon FTZ. adapter). Using an adapter without contacts and entering the lens data in the camera makes IBIS functional again.
Jürgen
Jürgen Pfeiffer
« Reply #1178 on: January 07, 2025, 20:52:42 »
Hello Ølvind,
Jürgen
Hi Jürgen, I am using the chips supplied by Birna in the past that unfortunately are not available any longer. I only have one Dandelion G-chip which is mounted on a reversal ring. On my Z8 I can easily hear when IBIS is active, so you should be able to confirm just by listening in a quiet place. The choices being grayed out in the menu or not would also be an indication.
Jürgen Pfeiffer
« Reply #1179 on: January 08, 2025, 11:37:33 »
Hi Ølvind,
thanks for your answer. With the Zf it's not so easy to hear the IBIS, maybe due to the different "fixation"? of the sensor compared to the Z8 (clicking sound when the Zf is turned off). But after some tests I have to say, that Dandelion chips don't support IBIS. So, if it‘s do decide between stabilization with chip and focus confirmation without chip, stabilization wins.
Jürgen Pfeiffer
Nasos Kosmas
  • Athens, Greece
« Reply #1180 on: January 10, 2025, 21:48:51 »
Moon and Jupiter, todays capture :)
« Reply #1181 on: January 11, 2025, 17:31:38 »
Is jupiter in the lower LH corner of your image Nasos?
It was wonderfully clear last night and i could see a few planets whilst out walking to the pub ;)
Nasos Kosmas
  • Athens, Greece
« Reply #1182 on: January 11, 2025, 22:53:07 »
Yes Colin it’s  in the lower LH corner of the image ;)
Yes it was very clear here also and I used Stellarium to identify that Jupiter is next to the Moon  8)
I also check  and show some satellites of Jupiter so 100% positive Identification!
Wait for moon- Mars approach as noted earlier.
« Reply #1183 on: January 14, 2025, 14:09:16 »
Mars and the moon, very early today. Mars is so tiny that I need a large screen to see it on the full picture.
D500 500/5.6 PF
Nasos Kosmas
  • Athens, Greece
« Reply #1184 on: January 14, 2025, 19:13:10 »
D500 500/5.6 PF
Nice capture Bruno :)
Now I see it’s so close :) unfortunately it’s heavy raining here last two days so I am gonna miss it
