Author Topic: [Theme] Show us your best moon (and solar system) images  (Read 355441 times)
« Reply #1200 on: May 06, 2025, 11:01:34 »
Back to the Sun, the sunspot active region AR4079 is is prominently visible right now even with just a pair of eclipse protective glasses. This one is from May 4. There is an interesting bright bridge between the two sub-regions of the spot. 500PF with TC-20E III on ZWO ASI 678MC, stack of the best 15% of about 1500 frames in 14 bit mode, stitch of two processed images. Open in new tab and click for larger size.
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
« Reply #1201 on: May 06, 2025, 12:21:33 »
Gorgeous. And is it a photography lens or a telescope?
« Reply #1202 on: May 06, 2025, 13:26:15 »
Amazing, as always.  Well worth viewing large!
« Reply #1203 on: May 06, 2025, 20:16:38 »
Thanks Akira and ARTUROARTISTA. Yes this was captured with the Nikon AFS 500mm f/4 E PF lens + TC-20E III at 1000mm f/11. This combination is well aligned to the 2um pixel pitch of the ASI678MC astro camera according to the commonly used "5x rule" of optimal ratio between F-number of the lens or telescope and and pixel pitch used in planetary astrophotography.
Nasos Kosmas
  • Athens, Greece
« Reply #1204 on: May 06, 2025, 21:59:48 »
Excellent capture Øivind :)
« Reply #1205 on: May 07, 2025, 00:22:33 »
Thanks, Nasos. Seems I was particularly lucky with the seeing on this occasion.
ARTUROARTISTA
    • APM Pintor
« Reply #1206 on: May 07, 2025, 08:56:22 »
Thanks Oivind for going into detail, you know how to do it, congratulations.
« Reply #1207 on: May 07, 2025, 10:08:12 »
Thanks again ARTUROARTISTA.
I can as well show the non-stitched IR capture I did before the visible light one above, converted to monochrome, although it is not quite as crisp looking. In both cases I used a Baader Astrosolar ND 5.0 film filter on the front of the lens. It is interesting that the brightness of the bridge between the two sub-regions of the spot also shows in IR.
Nasos Kosmas
  • Athens, Greece
« Reply #1208 on: May 07, 2025, 13:21:41 »
Øivind Is this an IR capture?, Is this a feature of the Astro camera ?
« Reply #1209 on: May 07, 2025, 19:32:34 »
Yes the ASI678MC is a full spectrum camera with just an AR protective window on the sensor that lets through everything from near visible IR to some way into the UV-A band. I takes 1.25" filters that are screwed in in front of the sensor. For visible light I use a ZWO UV-IR cut filter which includes wavelengths up the the hydrogen-alpha red band. For IR I have an Antlia 685nM IR pass filter. And I also have a UV pass but it requires a lens with good UV transmission which excludes most modern lenses.
However other models may come with a UV-IR cut filter on the sensor that has to be removed/replaced with protective glass for use with IR pass filters. This is the case with the newer ASI676MC, which has a square sensor also with a  a 2um pixel pitch and might be a good alternative to the ASI678MC.
Here is the ASI678MC with a 1.25" UV-IR cut filter mounted at the time:
Nasos Kosmas
  • Athens, Greece
« Reply #1210 on: May 07, 2025, 23:15:22 »
Thank you Øivind for the explanation  :)
« Reply #1211 on: May 08, 2025, 01:22:10 »
Impressive views Øivind, thanks for sharing it!
« Reply #1212 on: May 08, 2025, 04:41:46 »
Thanks, Paco.
« Reply #1214 on: May 28, 2025, 20:12:50 »
A new hi-res image of the sunspot has been published!
https://petapixel.com/2025/05/27/raging-sunspots-captured-in-crystal-clear-8k-by-new-camera-system/
Thanks for the link. it does look like it is using an advanced version of the lucky imaging technique we use for planetary/Lunar/Solar imaging, in combination with better sensor hardware. I always get a kick out of seeing how much more detail emerges when the wavelet transforms (I am using WaveSharp) are applied to a stack that is based on hundreds or even thousands of the best selected frames.
