Author Topic: What is a Flower?  (Read 2223 times)
What is a Flower?
« on: October 01, 2015, 20:26:14 »
Nikon D810, El Nikkor 105mm APO, Zerene Stacker
Re: What is a Flower?
« Reply #1 on: October 01, 2015, 21:40:45 »
Bosons and Fermions ... but to what effect ... wonderful bokeh to the perfect stack up front!
Patrick Berg-Pedersen
  • Nature and Landscape Photographer, Educated as a press Photographer for almost 30 years ago.
  • You and me, -Are the real legacy of Nikon
    • Patrick Berg-Pedersen
« Reply #2 on: October 02, 2015, 07:46:31 »
I really like hoe this turned out, the greens in contrast to the purple on the rest of the flower. Also knife sharp.
"The colour of light is almighty, it gives us not only day and night but the entire shape of life" - Patrick Pedersen
     -Proud Nikon FE2 owner since a age of 9!-
« Reply #3 on: October 02, 2015, 11:49:31 »
It scares how sharp and crisp it is. Amazing!
« Reply #4 on: October 02, 2015, 16:19:26 »
details??
« Reply #5 on: October 02, 2015, 16:24:45 »
details??
Not sure what you mean. I gave the camera, lens, etc. in the original post.
« Reply #6 on: October 02, 2015, 16:27:15 »
Impressive, gorgeous colors !  and very few artifacts
Thanks for sharing !
« Reply #7 on: October 02, 2015, 16:29:26 »
i guess it is the etc...
# of images in stack, aperture setting, shutter speed, flash??.. etc.. setup?.. post processing technique???
of course you could consider this much transparency somehow proprietary information which is fine... but it is what i meant by "details"
« Reply #8 on: October 02, 2015, 16:50:04 »
No secrets. 57 layers, natural light, wide open (f/5.6), ISO 64, 1/2 second. The El Nikkor 105mm APO requires a bellows, so I am using the Nikon PB-4, sitting on a geared head (Cube1) on a RSS tripod, series 3.  Then Zerene Stacker.
« Reply #9 on: October 02, 2015, 17:29:02 »
thank you... permits me a better understanding of your technique.. why was 57 layers chosen?.. .presumably you divided the object extent by the DoF for the lens to arrive at that value?
« Reply #10 on: October 02, 2015, 17:43:48 »
Nope. Not so scientific. I started at the front and went as far as I wanted to go.
