"NG 10 Years" competition: RESULTS !!!https://nikongear.net/revival/index.php?topic=11252.0Current status: 86/150 supporters
Thanks Akira5 images shot RAW Df, ISO400, 1/200 f9, AF-S 35mm f1.4 handheldJJ
JJ, thanks for the technical data and another nice pano. A 35mm lens seems to be more handy for panos than 50mm, if properly used like in your case.
When I use the 17-35/2.8 for pano's, in many cases the of 20-28 mm range is the preferred focal length. Subjects are usually city-pano's which may explain that choice.
Very wide view, Asle. A bit small to see the details.
It is a bit tricky to stitch frames with flare, but this time Photomerge seems to have worked pretty well.D750, AF-S50/1.8G. Three horizontal frames were stitched to this pano.
